Old 07-08-13, 08:19 AM   #1
Big Daft Lad
Default Debrix emulators - Are these the ones I need?
I’m about to fit a ZX6-R shock to my 2001 SV and wanted to do the front end at the same time. Can someone tell me if these are the correct fork emulators I need? Also do I have to buy them from the USA or is there UK outlet that stocks them?
http://www.debrix.com/41mm-Fork-Damper-Valve-2000-up-Harley-FXST-Softail-p/24-0361-vt.htm
Old 07-08-13, 08:24 AM   #2
Default Re: Debrix emulators - Are these the ones I need?
yes those are what you need, no uk outlet
Old 07-08-13, 08:26 AM   #3
Big Daft Lad
Cheers!
Old 08-08-13, 04:17 PM   #4
rapidgaz
rapidgaz's Avatar
what else is needed, and how do you adjust
rapidgaz is offline   Reply With Quote
Old 08-08-13, 05:30 PM   #5
If you have a curvy you need to open the damper rod comp holes up a bit and weld up the rebound hole
If pointy same as above and make a spacer to reduce the size of hole in the top of fork.
To adjust comp you need to fish it out of the fork and adjust it, but TBH for road riding you won't really need to.
Old 11-11-13, 02:19 PM   #6
The Black Grouse
I will be ordering DEBRIX EMULATORS
http://www.debrix.com/41mm-Fork-Damp...t.htm?CartID=1
I will order them on the 30th November.
let me know if you are interested...
More peeps = bigger discount!
[Rods being modified for the Emu's by YC (cheers)]
Kenny
Old 11-11-13, 06:14 PM   #7
Redmist
Can you point to specs on the spacer? Or can you provide them?
What size holes do the comp become?
Kenny
I'm in I'll PM you.
Old 11-11-13, 07:05 PM   #8
Runako
http://forums.sv650.org/showthread.php?t=177807
Old 11-11-13, 07:22 PM   #9
Redmist
Originally Posted by Runako View Post
OK will see if work can sort me out
Old 12-11-13, 04:28 PM   #10
The Black Grouse
yep redmist, not sure on total price yet, that'll be dependant on how many get in touch. PM me for confirmation that you want in on the order.
cheers
Kenny
pointy debrix emulators Trickster2445 For Sale - SV's and SV related items 21 16-06-13 05:16 PM
Debrix emulator group buy? gt900uk SV Talk, Tuning & Tweaking 105 20-05-13 07:54 PM
Debrix Emulator gt900uk Stuff Wanted 6 21-03-13 05:42 PM
Debrix emulators in an '01 Hornet - anyone done it? 85jas Bikes - Talk & Issues 12 12-11-12 12:19 PM
My Debrix emulator settings. peeterus SV Talk, Tuning & Tweaking 4 09-06-12 05:13 PM
