Combi Boiler is working when I turn on central heating and downstairs hot water tap is fine and working the taps in bathroom for hot water are not, no water pressure at all. I have tried resetting the boiler eith no effect gound pressure guage which was low so tried turning tsp made a noise and needle just kept bouncing on the spot, moved a little then dropped back down and no change any suggestions.
Or any boiler engineers etc in preston, lancashire area who could give it a look over and service at end of month? |
Yes Rumblebee on here is a gas engineer and all that lark.
Would you like his number ? |
Thanks will uou pm it do if needed I have it
PM electro, thats what he's doing for a living atm
sent from the shredded wheat factory
Try bleeding some radiators, you might have an airlock. Don't forget to add water back into your boiler after you have done this, to the pressure your boiler should be.
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
does cold water in bathroom work ok with good pressure?
Yes chris cold water taps in bathroom are same as usual, downstairs hot tap fine also, takes a minuet to warm up but thats usual
Radiators are on a different circuit to your hot water.
If it's more than one tap in your bathroom, i.e. sink and bath then it may well be an air lock. If it's just one tap then the gubbins inside might have come apart leaving the washer stuck in the pipe effectively. Sounds like a visit from a plumber is definitely in order. |
#9 |
I'd say a knackered tap as well.
If the heating works and the downstairs is ok then there's obviously no problem with the boiler/loop pressure etc.
#10 |
Knob faced knobster
Only just seen this, is it both basin and bath taps in the bathroom not working?
If it's just one tap then I would say it's the tap, I've lost count the amount times I've been called out for a broken tap etc and found either the washer has disintegrated or fallen off or the valve just needs stripping cleaning and re-greasing.
2011 Speed Triple 1050 |
Understanding Engineers. | ravingdavis | Idle Banter | 12 | 09-10-11 10:51 PM |
One to Interest YC and the engineers | andrewsmith | Idle Banter | 14 | 27-09-11 08:34 PM |
question for org plumbers and heating engineers | timwilky | Idle Banter | 12 | 28-10-10 09:24 PM |
Design engineers? | BanditPat | Idle Banter | 8 | 24-06-09 07:41 AM |
engineers report | Nicky S | SV Talk, Tuning & Tweaking | 25 | 21-03-09 08:38 PM |
