Old 16-01-14, 08:05 PM   #1
froymot
Default gsxr 750 front end swap curvy questions
hey guys
I have wanted to a fork swap on my sv for a while since I swapped out my forks for the later model adjustable ones after I was nocked off last year.
my local breakers have a gsxr 750 k4 I think- (could be wrong ive not seen it) and they don't want too much for the front end.
so my questions are:
does it matter what year gsxr they come from?
can i use the gsxr yokes?
is the stem and steering bearings transferable or will I have to make up shims to make it fit?
how easy is it to wire in a new sensor on the new front wheel for the speedo and calibrate?
any help would be awesome guys! cheers Tom
i enjoyed playing with the settings on these when i got them but would still like the upgrade
Old 16-01-14, 08:20 PM   #2
Default Re: gsxr 750 front end swap curvy questions
Seek and you shall find
http://forums.sv650.org/showthread.p...gsxr+fork+swap
Most of the info is here
Old 16-01-14, 08:24 PM   #3
froymot
you are a lamb xxx thank you <3
Old 16-01-14, 09:17 PM   #4
If you're doing the k4 swap, then you'll need one of these for the top yoke bearing
http://forums.sv650.org/showthread.p...pecial+bearing
Its not that hard to do, and probably the speedo sensor is the hardest part to get right
Here's the part you need for the sensor
http://www.digikey.co.uk/product-det...H398-ND/280932
Yet another Curvy GSXR front end swap. sicknote SV Talk, Tuning & Tweaking 13 24-08-12 03:10 PM
GSXR Front End Swap Kemp10 SV Talk, Tuning & Tweaking 43 02-12-08 04:47 PM
GSXR front end swap - front tyre profile. Khewett SV Talk, Tuning & Tweaking 12 11-05-06 11:24 AM
Do I have everything now for a GSXR front end swap?? Khewett SV Talk, Tuning & Tweaking 6 28-04-06 02:15 PM
