Old 26-01-14, 06:22 PM   #1
dalesv650
Default 02 curvy popping from exhaust, inlet manifold?
Hi everybody I'm new to this forum, I bought my second hand 02 curvy sv650 last week. It's been stood a while before I bought it and needed a new battery, after that it started fine but there is a popping coming from the exhaust. I've had the bike stripped down and I believe the front inlet manifold has been repaired and is now causing problems again due to the repair being old.
Old 26-01-14, 07:26 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: 02 curvy popping from exhaust, inlet manifold?
Moved to SV Talk
Old 26-01-14, 09:30 PM   #3
wideguy
I'd buy a new one.
Old 27-01-14, 10:54 AM   #4
dalesv650
I've purchased another inlet manifold from eBay, are the front and rear manifolds the same. Just turned 180degrees?
Old 27-01-14, 11:30 AM   #5
wideguy
They have different part numbers, which likely means no, not the same.
Old 27-01-14, 02:09 PM   #6
The angles might be different, or the spigots for front vacuum take off/ fuel pump vacuum take off different sizes.
Also the screws can be an absolute git to remove.
Old 27-01-14, 02:25 PM   #7
jambo
jambo's Avatar
I'll 2nd that having had a go at the weekend getting one off an old head...
Jambo
Old 27-01-14, 02:29 PM   #8
Impact driver and a PH3 bit.
Exhaust Popping. WeegieBlue SV Talk, Tuning & Tweaking 13 08-09-10 02:49 PM
Exhaust Popping And Banging Stewbie SV Talk, Tuning & Tweaking 10 01-02-09 02:31 PM
Laguna Exhaust Manifold removal. Stig Idle Banter 5 28-01-08 09:44 PM
After market Exhaust popping...bad? Kinvig SV Talk, Tuning & Tweaking 8 21-08-07 07:10 AM
popping exhaust at idle? toyotafj40s SV Talk, Tuning & Tweaking 5 21-08-06 01:31 PM
