Old 08-02-14, 04:02 PM   #1
Mikey360
Default Pointy Caliper play?
So finished the brake rebuild finally (new seals, pistons RR'd, new fluid etc)
I noticed that when the front brake isn't applied, both calipers have a slight play in them (ie move side to side less than a mm)
Everything torqued up just fine, 99.9% sure all the air has been bled out of the system and seem to be working (The front wheel locks if I run it up the garage)
Just wondered if this was normal or have I done something terrible?
Old 08-02-14, 04:30 PM   #2
jambo
jambo's Avatar
Default Re: Pointy Caliper play?
The calipers are on sliding pins. One part of the body will be solid as this is bolted to the fork leg, the other part will move on the sliding pins slightly when the brakes are not applied. Correct and normal.
Jambo
Sent without a real keyboard
Old 08-02-14, 04:53 PM   #3
Mikey360
Few, just thought id check!
Cheers Jambo
Pointy swing arm side play. DavieSV SV Talk, Tuning & Tweaking 158 20-03-15 11:03 PM
Swingarm play - Pointy chris c SV Talk, Tuning & Tweaking 10 12-07-13 04:50 AM
Pointy swingarm side play sorted. Bibio SV Talk, Tuning & Tweaking 27 29-04-12 08:04 PM
Pointy rear caliper dirtydog Stuff Wanted 5 07-01-11 08:53 PM
pointy rear brake caliper husky03 For Sale - SV's and SV related items 0 05-07-10 09:32 AM
