Old 17-02-14, 08:30 PM   #1
Badeye
Default Longer cables needed but where from?
Hi guys,
I'm putting renthals on my SV, but am obviously going to need longer cables as my SV is currently an S. Where can I get longer cables from?
Old 17-02-14, 08:46 PM   #2
DJ123
DJ123's Avatar
Default Re: Longer cables needed but where from?
IIRC the N model has longer cables
BMW F800ST
Old 17-02-14, 08:47 PM   #3
Wemoto, get ones for the naked SV, but you might not need them,if you reroute the clutch & throttle carefully.
On my Curvy, it was easier using the longer naked SV cables
Old 17-02-14, 08:50 PM   #4
Alexander94
Hi,
The clutch cable is a standard type so you should be able to get a longer one from anywhere, I personally use ebay a lot. As for the throttle cable I'd expect that to be a bit more difficult but it should be a standard type so I'd say the same for that too, look for the same type and ask the seller what the overall length is if it's not stated, hopefully this helps
Old 17-02-14, 08:54 PM   #5
Badeye
Thanks for the replies, so ya reckon if I get cables from the naked that should do it? Thanks a million guys.
Old 17-02-14, 08:54 PM   #6
If you need longer switchgear cables pm bibio on here. He sells extensions that plug straight in.
Old 17-02-14, 09:20 PM   #7
Badeye
That's really good to know, cheers bud
Old 18-02-14, 08:14 AM   #8
Jayneflakes
Jayneflakes's Avatar
Hi there, I have Renthals on my S model and huge risers too, for the clutch cable I used one from a DL650 V-Strom, via wemoto.
For the throttle cables, I had them custom made and once I had routed them properly they worked a treat. This was not expensive and was done by my local bike garage.
I extended the loom for my switch gear myself, by cutting the wires and splicing in a new section which I then soldered and covered with heat shrink. It took about an hour to do, but once it was all covered with a protective wiring tube, it looked great.
You can have a look at my thread on how I did it all if you like, just click here.
Good luck and enjoy.
Jayne you're a Pussy Magnet
Old 18-02-14, 01:02 PM   #9
Badeye
So been looking at some longer cable on wemoto and according to them the clutch cable length on the 99 N and the 99 S are different lengths but the choke cable is the same, how can this be?
Clutch Cable
99 SV N = 103cm
99 SV S = 98cm
Both Choke Cables are 99cm
Thottle Cables
99 SV N A(Pull) = 71cm
99 SV N B(Push) = 75cm
99 SV S A (Pull) = ??? - Can any1 help me out here?
99 SV S B (Push) = ??? - Can any1 help me out here?
Cheers,
Si
Old 19-02-14, 10:19 AM   #10
johnnyrod
johnnyrod's Avatar
I think Venhhill in Surrey used to do custom length cables, maybe still do
Pointy comfort kit - longer cables? leebex SV Talk, Tuning & Tweaking 9 06-05-13 09:33 PM
Renthal bars; longer cables needed? Jason H Bikes - Talk & Issues 6 17-03-13 08:06 AM
naked top yoke on an S, longer cables? cyphertheory SV Talk, Tuning & Tweaking 10 12-05-11 07:43 AM
longer cables barwel1992 SV Talk, Tuning & Tweaking 2 17-10-09 09:45 PM
Longer cables for a SV650S kojay SV Talk, Tuning & Tweaking 4 09-03-07 10:03 AM
