Old 18-02-14, 03:52 PM   #1
woodster
Default Front headlights failure - k5 pointy
Hi all
Went to switch on my bike today, as have not run it for 2 months and both the front headlights are not working .... sidelights OK and everything else works OK, but no headlights.
Pulled out both main and dip fuses and they appear to be OK with no breaks.
There is no bodged wiring that I can see and the bike is in immaculate condition. The only thing I have done to the headlights (and it worked with them) was to replace them with a pair of Philips Extreme Vision bulbs.
Any ideas? ...........
Old 18-02-14, 03:57 PM   #2
Nutsinatin
Nutsinatin's Avatar
Default Re: Front headlights failure - k5 pointy
Do you have pass lights and full beam, or have they gone too?
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 18-02-14, 04:01 PM   #3
woodster
Pass light and full beam both gone as well .....................
Old 18-02-14, 06:55 PM   #4
MJC-DEV
MJC-DEV's Avatar
Flat battery?
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 18-02-14, 07:06 PM   #5
woodster
nope ... started first prod. The blue warning light on the speedo doesnt come on either. was thinking left switchgear but horn and indis work
Old 19-02-14, 08:25 AM   #6
PyroUK
PyroUK's Avatar
That's annoying. There was another thread not that long ago about lights not working that sounds similar. The light on the dash sticks out in my mind. I'll see if I can find it and post back.
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 19-02-14, 08:32 AM   #7
PyroUK
PyroUK's Avatar
Haven't read the whole thread so don't know if there was a solution but check this:
http://forums.sv650.org/showthread.php?t=204934
Old 19-02-14, 12:23 PM   #8
woodster
Strange .... cleaned the connector for the lcd display and disconnected both headlight plugsand the the blue main beam indicator comea on when I switch to main beam. goes out when I plug in either of the headlights. Might be the battery or could it be the led sidelights?
Old 19-02-14, 12:51 PM   #9
PyroUK
PyroUK's Avatar
To be honest this is outside my expertise but, what are the connectors to the bulbs like?
If they are gummed up that may be causing a short or something?
What happens if you only connect one bulb at a time?
Help with 04 pointy front cylinder failure 650thunder SV Talk, Tuning & Tweaking 9 05-09-13 04:50 PM
Pointy complete electrical failure. quik_d SV Talk, Tuning & Tweaking 6 24-12-12 11:56 AM
Front sprocket oil seal failure. sv_rory SV Talk, Tuning & Tweaking 28 30-08-12 06:13 PM
Tail Tidy Failure (Pointy) Stonesie SV Talk, Tuning & Tweaking 11 01-11-10 04:40 PM
SV650 front cylinder failure chewy22 SV Talk, Tuning & Tweaking 20 27-10-06 07:22 PM
