Hi,
99 sv650s Do these wires need coonecting back to block, engine ran before bike was broken. |
#2 | |
![]() ![]() ![]() ![]() Hope these help, Pic 2 my old cable/ engine. Pic 3 conn block (rubber boot)under petrol tank Sent from my iPhone using Tapatalk |
That's the neutral switch wire and the 2nd/3rd gear signal to the ECU. Engine will run without them.
Sid, why would they be spliced in 1st place, common practice,performance mod? also would it still show neutral on dash?
Thanks Sent from my iPhone using Tapatalk |
The two that are disconnected need not be spliced, (but it doesn't matter if they are), they are the 2nd/3rd gear signal to the the ECU, and are removed to inhibit the ignition retard that made a Curvy pass the then current noise test, blue wire goes to the neutral light.
Appreciate your time, sorry for being a bit vague earlier.
Thanks again. Sent from my iPhone using Tapatalk |
#8 | |
Did this make the ECU restrict 2nd & 3rd ?? Don't get how it helped with noise
Curvy With Lots Of Bits ...
But Still More To Come ![]() |
#9 |
Restrict no, retards the timing a dab at certain revs in the two relevant gears as a means of ever-so-slightly depressing power output and thus reducing noise a bit so that the bike would pass the then current noise test.
If an SV650 has a flat tyre in the forest and no-one is there to blow it up, how long will it be 'til someone posts that the reg/rec is duff and the world will end unless a CBR unit is fitted? A little bit of knowledge = a dangerous thing. "a deathless anthem of nuclear-strength romantic angst" Last edited by Sid Squid; 13-03-14 at 08:25 AM. |
#10 |
Back again,SS, do you recommend connecting as per original block if mot spec no longer applies?
Extending Wires In A HID Kit? | CAhmroiss | Bikes - Talk & Issues | 0 | 05-01-14 09:20 PM |
Which headlight wires curvy sv650s | Elltg | SV Talk, Tuning & Tweaking | 5 | 14-06-10 11:20 PM |
Strange wires??? | krhall | Bikes - Talk & Issues | 5 | 16-03-07 12:58 PM |
2nd/3rd wires | andy owen | SV Talk, Tuning & Tweaking | 1 | 29-01-06 05:08 PM |
chafing wires | philb | SV Talk, Tuning & Tweaking | 3 | 13-06-05 06:34 AM |
