Old 04-05-14, 05:09 PM   #1
Red ones
Red ones's Avatar
Default Car help needed. DPF problems
Anyone on the great ORG who knows anything useful about DPF problems?
I have a Zafira which now has a fault light that suggests the DPF is full.
The web I a useless as usual. Everything from remove it, to £1500 repair bill. Even suggestions it's about half an hour of work if you find someone with the right bit of gadgetry to clean it.
Any ideas?
Old 04-05-14, 05:27 PM   #2
Tomor
Tomor's Avatar
Default Re: Car help needed. DPF problems
Get it gutted and forget about it. It is a visual MOT inspection now, so you will need to leave the canister in place, just remove the internals and have it welded up. May need to get it removed from the cars memory though, otherwise it will constantly throw problem light
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 04-05-14, 07:23 PM   #3
Mr Speirs
Mr Speirs's Avatar
Take it on a long journey and rag it. Isn't that supposed to clear it?
Old 04-05-14, 08:15 PM   #4
NTECUK
NTECUK's Avatar
Not rag it. It's higher than normal RPM constant cruise.
But vaxhall are known for it.
Reprogramming the ecm and remove the dpf internals it's a good plan.
Old 04-05-14, 09:36 PM   #5
punyXpress
punyXpress's Avatar
AKA: Italian Tuning
Now: Street Triple R
Old 05-05-14, 02:58 AM   #6
cb1000rsteve
I have the 120 bhp cdti engine and have had 2 faults which wrongly point to dpf failure. One is the pipe from the dpf to the sensor that tells it is broke. From under the car it's above the exhaust level with back of the engine. It's a hard plastic pipe which over time breaks causing a false reading (great design vx). To replace this pipe costs £30 from vx but a fuel line and 2 jubilee clips cost £5 and does the job. The other is the sensors broke which this pipe enters. It sits behind the top of engine attached to filter if memory serves?
This costs £55 from Andrew pages and is a five minute job.
My zafira is an 08 plate, done 80,000 miles.
Old 05-05-14, 03:04 AM   #7
cb1000rsteve
If it is blocked then first
To regenerate the dpf you need to travel at a constant above 2000rpm for about 20-30 minutes. U should notice your fuel consumption drop to about 33mpg on computer
Second:
Forced regen by a garage with op com type software
Third:
Take dpf off and clean it out with caustic and a jet washer
Fourth:
Have it ripped out welded up and re programmed out. £320 and upwards
Last option
Replace dpf which by vx is £1000+ but u can get them off eBay for a lot less and bolt them in.
My betting is the pipe or sensor.
Old 05-05-14, 12:13 PM   #8
Red ones
Red ones's Avatar
Cheers guys.
I had a nose around this morning but can't get the car up enough to have a good look for the hose. I ran it up the motorway for an hour last night to no avail.
Looks like it's going to the garage tomorrow. Wouldn't mind quite so much if the AC worked, the central locking locked or the stereo could play CDs!
Old 05-05-14, 12:19 PM   #9
NTECUK
NTECUK's Avatar
Have you got a code scanner
Old 05-05-14, 03:42 PM   #10
cb1000rsteve
U don't need one on zafira. Just do the brake pedal test. Brings the codes up on the dash then just google the codes.
Gmail calendar problems - Help needed Littlepeahead Idle Banter 4 06-12-12 03:57 PM
Computer Problems - Help Needed Jp Idle Banter 1 30-08-06 10:51 AM
2001 sv650 engine problems, help needed Dreadhead SV Talk, Tuning & Tweaking 5 15-03-06 01:42 PM
Problems Jezza SV Talk, Tuning & Tweaking 8 05-09-05 12:40 PM
And we think we have problems BURNER Bikes - Talk & Issues 1 28-07-05 01:20 PM
