For Sale - Other Bikes and General biking items For other bikes, clothing, helmets etc. Unsanctioned trade ads will be deleted as will spam and chat. Anything not relevant to motorcycling will be moved to Idle Banter |
2 sets of part worns;
Bridgestone Battlax BT021: 120/60ZR 17 Date stamp 17/09 Tread left; left side - 3mm middle - 2.5mm right side - 3mm There is a nick in the rubber just below the rim edge but unless you're cranked right over I don't think this would cause any problems. 160/60ZR 17 Date stamp 21/09 Tread left; left - 5.5mm middle - 5mm right - 5mm £50 for the pair Maxxis Supermaxx 120/60ZR 17 Date stamp 27/10 Tread left; left - 3mm middle - 4mm right - 3mm 160/60ZR 17 Date stamp 47/10 Tread left; left - 4mm middle - 4mm right - 4mm £60 for the pair PM me with an email address and I'll send photos over. Collection preferred but happy to send by courier if you can arrange this your end. Cheers, Dave |
I can send each set by courier for £10.
Are the maxxis ones the ones with the diamond tread on the edge? and are there any flat spots on the tyres?
I've just had a look and can't see any diamond tread mate, also no sign of any flat spots.If you pm me an email address I'll send what photos I've got over to you.
Bridgestone set now £50 inc postage
Maxxis set now £60 inc postage |
Willing to split the 120/60ZR 17 Maxxis? As I only need a front for the moment and don't have anywhere to store the rear if I bought both.
No problem, the tyres individually will be;
Bridgestone Battlax BT021 front £25 inc postage ***Bridgestone Battlax BT021 rear £35 inc postage SOLD*** ***Maxxix Supermax front £30 inc postage SOLD*** ***Maxxix Supermax rear £40 inc postage SOLD*** There isn't much difference in cost to send a set or just a single tyre. Last edited by Bunkle; 28-05-14 at 04:52 PM. |
Any chance of a pic of the Maxxis front and your preferred method of payment? If happy with pic I can pay for it later tonight.
Sent using a device that allows me to coalesce my thoughts with radio frequency waves and transmit them over long distances. |
#9 |
No cupping on the 21's? If not ill take the rear.
Sent from my GT-I9505 using Tapatalk
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. Last edited by muzikill; 25-05-14 at 07:15 AM. |
#10 |
Entropy - PM sent bud.
Part worn tyres | Wildkid | Stuff Wanted | 0 | 12-01-13 07:56 PM |
Part worn tyres | Serdna | Stuff Wanted | 5 | 18-10-11 09:52 PM |
Part Worn Bridgestone Front Tyre | TamSV | For Sale - Other Bikes and General biking items | 1 | 15-05-11 11:36 PM |
Part worn tyres | toby_smith | For Sale - Other Bikes and General biking items | 0 | 05-08-10 11:42 AM |
Part worn tyres | Endellion | For Sale - SV's and SV related items | 4 | 11-02-10 11:47 AM |
