Old 05-09-14, 08:31 AM   #1
Ratty
Ratty's Avatar
Default SV1000SZ running poorly. Fault fining help please.
Hi guys. Looking for a little guidance fault finding a problem on my brother-in-laws SV1000SZ. He just bought it and brought it back from down south in a van. His test ride went well and it’s run well for a couple of days. Bringing it down to show me last night it started to run rough and would not hold tick-over. The only thing he has done prior to this was wash the bike and a hose was used.
There is definitely lower output from the RH exhaust and its also missing on that side. I only had an hour to look at it last night as it was going dark, but these things I checked: -
Front plug drain hole is clear and no water present. Rear plug was very sooty but dry. I put one of my old ones in and it started well then went the same. I didn’t attempt to get at the front plug due to time.
Air filter is a K&N and could do with a clean, but is not filthy.
Engine very sounds good ( much better than mine ) with no obvious problems and the battery is very strong. £10 of new fuel was added after the problem started. It has loud cans on.
Bike has a good service history and 20000 on the clock. The bike had not been run for about 4 months up to the sale this week.
I can do most things mechanical but have never messed with FI, throttle bodies etc other than to attach vacuum gauges to mine.
I would be grateful if you more experienced guys could give me an idiot guide to sequence of fault finding this sort of problem. I’m suspecting a leak / blockage around the TB’s.
Thanks in advance. Alan
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 05-09-14, 08:54 AM   #2
NTECUK
NTECUK's Avatar
Default Re: SV1000SZ running poorly. Fault fining help please.
My RSV-R had petrol that had gone emulsified. ran very much like you describe.
To check for air leak .easy way is spraying wd 40 round the throttle bodies.
Pointy running poorly. sKiTz-0 SV Talk, Tuning & Tweaking 17 19-04-19 06:49 AM
Curvy running poorly. Alexander94 SV Talk, Tuning & Tweaking 17 16-02-14 07:07 PM
Curvy running poorly. craig dow SV Talk, Tuning & Tweaking 8 02-10-12 08:55 PM
Running poorly and popping. sjoerger SV Talk, Tuning & Tweaking 5 20-08-10 12:43 PM
running poorly matt_rufus SV Talk, Tuning & Tweaking 8 15-04-09 08:25 PM
