Old 06-02-15, 05:47 AM   #1
glyn
Default carb sinc
Hi all
can someone help me on sincing carbs.I have basic skills. Is there a way to gdo it without buying a manometer.
thanks in advance
Glyn
Old 06-02-15, 06:48 AM   #2
Default Re: carb sinc
You can make your own manometer, but to do it without one is probably impossible.
Goolge on how to do a diy one.
If not see if there's a orger nearby you, who has one?
Old 06-02-15, 08:20 AM   #3
Mark_h
Mark_h's Avatar
If you've got a good ear you can try tweaking it until you get an even sound. When using the gauges you can certainly hear when it comes into sync, question is can you do it without. Make a note of how much you've twiddled and if it makes matters worse put it back how you found it.
Out of sync it'll make a badomp badomp badomp noise. In sync it'll go bomp bomp bomp bomp.
Minister for Sustainability
Old 06-02-15, 12:38 PM   #4
glyn
I'm in Rochdale lancs if anyone can help
Glyn
Old 06-02-15, 12:40 PM   #5
johnnyrod
johnnyrod's Avatar
Try posting in the Pennine Massive section. You really need either a manometer or vacuum gauges though.
Old 06-02-15, 12:54 PM   #6
Yorkie Chris is only 30 mins away from you, plus a few others
Carb set up help harry_hyde Mini-Twins 3 21-02-12 09:50 AM
Wanted: Clocks for carb model naked + headlight and carb. Gazdaman Stuff Wanted 2 17-03-10 03:50 PM
Carb Help. Phaelok Bikes - Talk & Issues 9 01-07-09 02:14 PM
pipes going to carb to carb sv650nutter149 SV Talk, Tuning & Tweaking 3 07-09-08 10:16 PM
Sinc and the Art of Motorcycle Crash Recovery! Cat Bikes - Talk & Issues 196 12-01-05 09:43 PM
