Old 02-09-15, 04:47 PM   #1
s7even
Default LED indicators
HI , I have a 2014 SV650 and I've been told that you can fit LED indicators to it without adding resistors or a new relay? .. is this correct are they just plug and play ?
Thanks
Old 02-09-15, 05:24 PM   #2
Default Re: LED indicators
unless suzuki have changed the relay (very much doubt) then i dont think so.
Old 02-09-15, 07:02 PM   #3
s7even
so all i need is the relay and the indicators ? and is the relay just a plug in
Old 02-09-15, 07:32 PM   #4
Yes, you can get a relay that just replaces the oem that works with LEDs. Look on ebay, plenty of choice, but go for a uk seller.
My oxford nano led's come with resistor, and are straightforward to fit, so i didn't need a relay.
Just remember that most led's come with bullet connectors and you will need 4 adaptors to convert bullet to suzuki connectors, saves cutting the wiring.
Also if yours is a faired model then you will also need some Indy Spacers to fit the LEDs in the fairing
Old 02-09-15, 08:04 PM   #5
Toooldtodie
Toooldtodie's Avatar
Sometimes the resistors don't work as supplied.
Also remember that the resistors turn the surplus electrical energy into thermal (heat) energy, so locate them well away from plastics or anything else that may be affected by it, they can become hot enough to melt plastic easy.
That said, they look well smart and bright and they go better with the led tail-light.
Also read what maviczap also says about the spacers and connectors, before you start.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 02-09-15, 08:29 PM   #6
I suspect the cheapo ones don't work properly, my Oxford Nano's are well made & the quality is very good. They are a bit more expensive, but they've never given me any problems
Old 04-09-15, 04:02 PM   #7
s7even
i`ve bought the relay and indicators , do i need spacers for the front and the back ?
Old 04-09-15, 04:22 PM   #8
yes.
Old 04-09-15, 07:26 PM   #9
yes.
For the front yes, and only yes if you've still got the standard rear mudguard
Mines got a Powerbronze undertray & a different number plate hanger, so I didn't need spacers for the rear
Old 04-09-15, 07:42 PM   #10
s7even
Standard at the moment .. Thanks guys .
Indicators - where from? collis SV Talk, Tuning & Tweaking 3 20-07-11 07:31 PM
Micron Front Paddock stand, Arrow-style LED indicators, Chrome Eagle-Eye indicators, Rear paddock stand Aluminium bobbins for swingarm.... lucky strike For Sale - Other Bikes and General biking items 12 27-08-09 12:00 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
Indicators enabb For Sale - SV's and SV related items 2 11-12-05 10:42 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
