Old 29-03-16, 11:01 AM   #1
Dave Johnston
Default Gladius front wheel in GSXR forks
Need a bit of help if anyone knows, I've just bought a gladius and a set of GSXR forks with the radially mounted Tokico calipers. But rather than fitting the 3 spoke front wheel i wanted it to match the back, so firstly can i fit GSXR discs and space them out from the hub faces to suit the calipers or am i better trying to fit an R6 front wheel that looks similar as I've heard this is possible.
I also have my own fabrication and machining business so modifying spacers etc is not an issue
Thanks
Dave
Old 29-03-16, 03:09 PM   #2
Default Re: Gladius front wheel in GSXR forks
Thanks
Dave
You've almost answered your own question. Not many Gladys on here, let alone modified.
There's few swaps been done on SvRider, so check out the info there.
https://www.google.co.uk/webhp?sourc...%20front%20end
Someone with a bit more technical know how will answer your post on here
Old 31-03-16, 09:36 PM   #3
Dave Johnston
Thanks for pointing me in the right direction
Old 01-04-16, 06:17 AM   #4
Keep us updated to the progress as you'll be the first to do this
Old 01-04-16, 07:20 AM   #5
Dave Johnston
Will do, I'm trying to build a mini twin style bike for the road with gsxr fairings or something similar so by the time I'm done I should have come across a few more problems which I will post answers too.
GSXR RWU forks and stock SV wheel? xlv SV Talk, Tuning & Tweaking 12 12-11-12 07:05 PM
Srad wheel on gsxr 1000 k2 forks? widget Bikes - Talk & Issues 3 19-10-10 11:35 AM
Fitting GSXR front mudguard to GSXR USD forks maviczap SV Talk, Tuning & Tweaking 1 20-02-10 10:05 PM
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
K4 gsxr forks - which wheel? buttmunch SV Talk, Tuning & Tweaking 25 31-05-06 11:28 AM
