Old 11-08-17, 08:40 PM   #1
DomP
Default Sprocket change
Search function is boring so my question for you all is if I'm due s nest chain and sprocket set do I take the opportunity to drop a tooth on the front?
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 11-08-17, 10:43 PM   #2
Default Re: Sprocket change
better going up on the rear as going down on the front can chew the swingarm.. keep it clean now
Old 11-08-17, 10:47 PM   #3
DomP
Lance has been drinking!
Old 03-09-17, 03:15 PM   #4
EnhancePW
Definitely worth a change in gearing I went up 3 on the back on my curvy and it's made an incredible difference, I would never look back to putting standard sizing on
Sent from my SM-T585 using Tapatalk
Old 03-09-17, 03:16 PM   #5
DomP
Did that require more links in your chain?
Old 03-09-17, 03:27 PM   #6
EnhancePW
That I'm not sure about mate, my bike guy done it all for me while it was in for a service all I know was that he said I had to remember the sizing set was the same as the gladius so it will be whatever length of chain comes with a gladius sprocket kit. I lost about 10mph of the top speed so now makes at 120, but the gain in acceleration more than makes up for it, and still has loads of pull if you need to overtake in top gear without having to drop a gear
Old 03-09-17, 03:33 PM   #7
DomP
Standard sv 0-60 is 3.7 isn't it? How much of a change is it, what sort of bikes will you be out accelerating?
Old 03-09-17, 03:57 PM   #8
EnhancePW
Yeah that sounds about right, I think this will have brought it down to 3, ( i think tge gladius is 3.1) I've never actually timed it, however my mates gsxr600 can't keep up till about 100 110 then he just sneaked past, accelerates past a Daytona 675, the aprillia shiver 750 can only just keep up, I can stay hot on the tail of my mates blade till about 80 then he starts to slowly pull away but not enough to think god he has smoked me, so around the twisties there's not much that can pull away or keep up.
Honestly will be the best upgrade you make, there's a slight gain with revs on the motorway by about 500rpm cruising but I can live with that
Old 03-09-17, 03:58 PM   #9
DomP
Hmm... food for thought come chain and sprocket change time.
Old 03-09-17, 04:01 PM   #10
EnhancePW
Absolutely mate, it's great fun, I spent ages thinking do I don't I, glad I did, it has left me thinking that was a close call a few times mind, when giving it a handful out of a corner and the front end lifts (not just fork travel) you'll enjoy it for sure
Curvy - Sprocket change Citizen SV Talk, Tuning & Tweaking 3 14-07-14 08:31 PM
chain and sprocket change? Quiff Wichard Bikes - Talk & Issues 23 11-04-13 10:22 AM
chain and sprocket change stephencassidy SV Talk, Tuning & Tweaking 17 05-09-09 03:18 PM
Front sprocket change Fuzz SV Talk, Tuning & Tweaking 4 21-04-06 12:24 PM
Ok to change the sprocket at the 1st service? kevin1970 SV Talk, Tuning & Tweaking 3 29-08-05 04:58 PM
