Old 14-07-14, 06:46 PM   #1
Citizen
Default Curvy - Sprocket change
So as my 2000 curvy was making some weird noise from the front sprocket and coupled with the chain being knackered at the weekend it was sprocket change time.
I had a feeling it was pretty shot but didn`t expect this:
Talk about fubard, the replacement was a Renthal 14 tooth and I reckon they were the same size (the one in the pic isn`t it) so no real noticeable improvement, but I can`t help thinking the chain could and would have come off at any time and it doesn`t bear thinking about.
Anyhows new front and rear sprockets and a nice new gold did xring chain and all is well.
Old 14-07-14, 06:54 PM   #2
Tomor
Tomor's Avatar
Default Re: Curvy - Sprocket change
Bleedin 'eck!!!
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 14-07-14, 07:17 PM   #3
muzikill
muzikill's Avatar
And thereby warrants everyone to check behind the sprocket cover on a regular basis.
Sent from my GT-I9505 using Tapatalk
Old 14-07-14, 08:31 PM   #4
squirrel_hunter
squirrel_hunter's Avatar
I've MOT'ed worse.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Curvy rear brake disc, sprocket and sprocket carrier Bunkle Stuff Wanted 2 05-04-14 10:08 AM
chain and sprocket change? Quiff Wichard Bikes - Talk & Issues 23 11-04-13 10:22 AM
chain and sprocket change stephencassidy SV Talk, Tuning & Tweaking 17 05-09-09 03:18 PM
Front sprocket change Fuzz SV Talk, Tuning & Tweaking 4 21-04-06 12:24 PM
Ok to change the sprocket at the 1st service? kevin1970 SV Talk, Tuning & Tweaking 3 29-08-05 04:58 PM
