Old 18-07-18, 05:35 PM   #1
Mark_h
Mark_h's Avatar
Default SV1000 K3 FI light :(
It's been ages since I posted on here but I need help. My old faithful SV1000 is having problems.
For the last 10+ years she's started on the button each and every time. This week I've been using the bike to ferry my son to and from the airshow so it's been doing some short, 5-10 mile journeys and getting used more frequently than usual. We've also done a few 50-100 mile journeys over recent weeks. so pretty much getting used more than normal and a few short trips thrown in. It's also been scorchio around here with day-time temperatures hitting 30+ while bike is parked up.
The last couple of days when I start from cold, it cranks but does not fire then throws an FI light. If you switch on and off a couple of times it goes through the priming sequence and then starts and runs fine. Once it's started, if you kill it then it starts fine. Leave it for an hour or so and it will start fine again.
Leave it overnight and it'll crank, give an FI light and you have to go through the priming sequence.
Any suggestions on where to start looking? Not sure if it's a temperature related thing or perhaps losing pressure in the system somewhere No petrol smells that I can notice to indicate a leak.
Never had any problems like this before.
Not lifted the tank or done any investigations at all yet as, to be honest, I was unsure where to start.
Probably entirely unrelated but the right indicator came on and did not flash at one junction on the way home this evening. Pretty sure the flasher relay is part of the side-stand interlock gubbins on these so is there a chance this is connected? I suspect a red-herring but you never know.
What do ya recon?
Minister for Sustainability
Old 18-07-18, 07:25 PM   #2
glang
Default Re: SV1000 K3 FI light :(
you need to put it dealer mode and see the code that comes up which should then tell you where the problem is. Best to download the manual or look up how to do this on here.....
Old 19-07-18, 11:49 AM   #3
andy650
+1 You need dealer mode. Short the 2 pins in the empty white connector under the seat, that will show you the code on the dash. Look it up, and go from there.
andy650 is offline   Reply With Quote
SV1000 Nose/Light/Stay (Fits 650) Or Curvy Conversion CLARKYsv For Sale - SV's and SV related items 2 12-05-15 11:07 AM
halo twin light conversion for naked sv1000 MAD MONK SV Talk, Tuning & Tweaking 26 19-02-15 06:48 PM
SV1000 range after yellow light Mark_h SV Talk, Tuning & Tweaking 7 21-05-13 02:43 PM
Fuels warning light - SV1000 Mark_h SV Talk, Tuning & Tweaking 7 05-05-08 02:12 PM
clear tail light / stop light Lens for sale SVTONYB For Sale - SV's and SV related items 7 20-05-07 04:55 PM
