Old 04-07-25, 02:53 PM   #1
mkr
mkr's Avatar
Default whirring noise
whirring noise when i close the throttle, disappears when pull clutch in, clutch working fine, nice noise, like turbo winding down, noise shouldn,t be there though, bike done 50000mls, any ideas,? plan at moment is to ignore and keep fingers crossed.
mkr is offline   Reply With Quote
Old 04-07-25, 08:31 PM   #2
garynortheast
garynortheast's Avatar
Default Re: whirring noise
Does it make the noise in neutral or just in gear?
Blue Curvy S with over 110,000 miles and still going strong.
Old Yesterday, 05:28 AM   #3
mkr
mkr's Avatar
Cool Re: whirring noise
different speeds but typical example would be, doing fifty mph, close throttle as if to slow down, noise appears, pull in clutch, noise disappears, let clutch out noise will reappear, any gear, any moderate speed or high speed, accelerate and noise disappears. open throttle no noise, close throttle noise. nice noise but shouldnt be there.
Old Yesterday, 05:31 AM   #4
mkr
mkr's Avatar
ps, no noise in neutral stationary, havent tried neutral at fifty!
Old Yesterday, 08:12 AM   #5
garynortheast
What you describe would point to the gearbox.
Old Yesterday, 09:25 AM   #6
admin
John T
admin's Avatar
Might be the gearbox but the gears would still be spinning with the clutch pulled in as they would be driven my the rear wheel. I'm wondering if it's coming from the intake as the noise appears when the throttle is closed creating high air pressure.
Old Yesterday, 10:13 AM   #7
Could be too tight a chain.
Old Yesterday, 11:50 AM   #8
mkr
mkr's Avatar
dont want it to be gearbox, although i was thinking the same. not going to touch gearbox, so will be fingers crossed ploy.
Old Yesterday, 11:56 AM   #9
mkr
mkr's Avatar
dont think airbox, though i think it might be gearbox like gary north east says, i also thought like you all gears and bearing would still be turning so the noise should stay with clutch pulled in, but could be gearbox under load and then not under load
Old Yesterday, 11:59 AM   #10
mkr
mkr's Avatar
dont think chain too tight, but could be worn chain perhaps, might take a deeper look at chain and sprockets
Whirring noise at switch on? Stephen McG SV Talk, Tuning & Tweaking 19 07-04-13 10:10 PM
Top-end noise? Timothy Quinn SV Talk, Tuning & Tweaking 2 06-01-12 05:08 PM
New chain and sprockets- "whirring" noise twopots SV Talk, Tuning & Tweaking 4 20-08-09 10:55 AM
Strange Whirring Noise Buffty SV Talk, Tuning & Tweaking 2 11-01-08 12:04 PM
Screeching noise? what noise does your SV make? branny SV Talk, Tuning & Tweaking 5 30-06-06 12:09 PM
