Old 01-11-04, 10:28 AM   #1
homersimpson
Default Electrics - Help needed....
Help some of me electrics have stopped working.
Last week when i was riding back to work i noticed the oil light flicker on when the engine was idle. As soon as i increased the revs it would go off.
So after a good wash (not pressure wash with bike running) yesterday i noticed the same thing happening, so i checked the oil level and thought it looked low so topped it up and started the bike up no problem.
Then disaster struck, the neutral light went out and also my trip clock, indicators dont work and neither does the horn. No Brake light either.
So i turned it off and started it again, started fine with dipped headlights and full beam ok but still no indicators, neutral light, tripcounter, horn or brake light.
Are these things all on the same circuit ?? Could it be a fuse or a short ? What should i check first ??
Please help as it was a great day for the bike to work today and i had to sit ****ed off in the traffic.
Thanks in Advance.
Simon
nb its an orginal sv s i have.
Old 01-11-04, 11:10 AM   #2
fizzwheel
fizzwheel's Avatar
That happened to me
Its a blown fuse, fuse box is under the seat go through them one by one until you find the blown one
I expect its one of the main 30 amp fuses thats gone, sorry to be vague but I took my bike to a dealer to get it fixed because I couldnt work out what happened, but my bike was completely dead it had nothing not even headlights and it wouldnt start sounds like yours is a bit different.
Also I found the cause of the fuse blowing, it was caused some some leads rubbing against the frame and the insulation had worn off and the bare wires were shorting the electrics
hope this helps
Old 01-11-04, 11:45 AM   #3
Flamin_Squirrel
The main fuse is 30amp, and there is only one. Everything dies if that goes though, so thats not it.
Old 01-11-04, 12:54 PM   #4
homersimpson
thanks for the replies.
so the main fuse isnt blown, could it be one of the other ones then ??
Will have to wait till tongith till i can have a look.
Simon
Old 01-11-04, 03:28 PM   #5
snoopy
The SV has an electronic trip for the indicators, if your short they go of until next restart of the system (key-off-on). This also applies for horn and brake lights.
Seems to me that you've got a shafted wire shorting to ground. First step is disconnect your rear electrics under main seat (indicators, plate light, brake light). If horn starts working then the shaft is rear end.
Remember you must turn electrics off and on every time you try.
Old 02-11-04, 01:37 PM   #6
homersimpson
15 amp fuse blown so replaced and tested, it blew again when i touched the rear brake so more investigation needed in that area as well as another couple of fuses.
Simon
Old 02-11-04, 02:08 PM   #7
Flamin_Squirrel
Well at least you know where the problem is now. Best O luck
Old 04-11-04, 12:41 PM   #8
simon-temple
well now you are on the right tracks.
let us know which area has the problem so we can all keep an eye on it.
Simon
What now?...electrics Dave20046 SV Talk, Tuning & Tweaking 138 21-04-09 09:48 AM
No electrics toffo SV Talk, Tuning & Tweaking 3 10-03-09 05:34 PM
car electrics help plz Wideboy Idle Banter 11 22-03-08 02:42 PM
Electrics. seandixie SV Talk, Tuning & Tweaking 13 15-02-08 02:07 PM
Messed up with electrics - help needed dclifford SV Talk, Tuning & Tweaking 3 11-02-07 07:29 PM
