Old 20-12-04, 11:00 AM   #1
BillyC
BillyC's Avatar
Default Scottoiler (K3/4)
I unpacked my Scottoiler over the weekend, and tried to get to grips with all the tubes and fixings.
Thanks to Mr Squid for giving me details of how to connect to the vacuum on the K3, have located that bit no problem!
So, what I'm looking for from you peeps is descriptions of where you've fitted your oiler reservoir, and how you've directed the tubing down to the swing-arm and onto the chain. Ideally I'm after pictures, and detailed descriptions... can anyone help? I'd rather not start super-gluing things to my swing-arm if possible
Squid: I'd really appreciate a look at how you've done the mounting on your swing-arm if it's possible for you to send/post a piccy of it. Ta
Old 20-12-04, 11:11 AM   #2
Flamin_Squirrel
Do you have your pilion pegs attached? Since I've removed mine, I bolted the reservior using one of the holes where the pegs normaly attach. The tube then runs down by the shock (kept taught to prevent the chain rubbing on it), and cable tied to the underside of the swing arm. I put it there to avoid losing the already limited underseat space.
I've not really got the delivery tube idealy placed however, something I really should sort out
Old 20-12-04, 12:00 PM   #3
Mr Toad
under the pillion seat, then the tube out and round near the front sprocket, and underneath the swingarm
I'll post some pics tonight if you want. Would show you on Weds, but can't make it this week due to babysitting
Old 20-12-04, 12:39 PM   #4
BaggaZee
On the K2 there's a threaded hole in the frame behind the LHS black vented plastic thing under the main seat. This happens to take the little scottoiler bracket bolt perfectly and you don't lose any storage.
The pointy bikes may have the same. Worth a look.
Old 20-12-04, 12:59 PM   #5
I've got the reservoir mounted below the sidepanel on the left hand side, cable tied to the frame, there's plenty of room for it there and it doesn't stand out particularly, actually it's fairly neat fitting in the space, on my 650SX I had it under the pillion seat but outside of the luggage space, that's not possible on the present bike, as there would be no access for filling and adjustment, I'll take a picture of the delivery tube plate tonight.
Old 20-12-04, 07:41 PM   #6
Jdubya
Default Re: Scottoiler (K3/4)
I got some pics off-of cloggsy...shall I mail 'em to ya?
Old 20-12-04, 08:57 PM   #7
Torn
can you send them too me please, ive had a scottoiler sat on my kitchen table for 2 months, also any hints on where to attach the vacuum would be most appreciated
Old 20-12-04, 09:53 PM   #8
Flamin_Squirrel
Check the scottoiler webside for pics of where to attach the vaccum tube.
Old 20-12-04, 09:54 PM   #9
Carsick
The scottoiler website might not seem all that great, but the guide is accurate and for a K3/4 it does literally attach the way the photo shows.
Old 20-12-04, 10:16 PM   #10
Cloggsy
If anyone wants the 'How to...' just ping me an e-mail & i'll send it to you
It's a big file 5+Megs (word doc,) so make sure your e-mail provider can receive big mails
Scottoiler Mk 7 vardypeeps SV Talk, Tuning & Tweaking 4 29-12-08 04:44 PM
Scottoiler ihitge Bikes - Talk & Issues 10 12-08-08 03:37 PM
Scottoiler Dualcyclone SV Talk, Tuning & Tweaking 45 15-03-08 04:46 PM
?? scottoiler ?? DoubleD SV Talk, Tuning & Tweaking 20 16-08-06 04:51 PM
Like a scottoiler for £15 Stu For Sale - SV's and SV related items 0 06-07-06 12:35 PM
