Old 16-02-05, 02:32 PM   #1
ahlb0018
Default Signal Resistors...
I just bought some new LED indicators for the front, and they are flashing way too fast so I figured that I would need to get a pair of resistors to slow them down. But, herein lies the problem... What type of resistors do I get? There are a wide variety of resistors, and I have not a clue which one works best. Anyone out there have any experience with resistors on your 03+ SV650?
Thanks in advance!
Old 16-02-05, 03:25 PM   #2
BillyC
BillyC's Avatar
Ah... we already had a big discussion on this, see here:
http://forums.sv650.org/viewtopic.php?p=241672&
Old 16-02-05, 03:32 PM   #3
ahlb0018
Default Thanks!
Thanks a lot! Cheers!
Old 16-02-05, 03:44 PM   #4
Grinch
I thought if you contact the company the made them they send out a little kit that fixes the problem for that bike, I know a guy with a bandit 12 that did that with his motrax ones.
Old 16-02-05, 05:34 PM   #5
embee
embee's Avatar
Default Re: Signal Resistors...
Originally Posted by ahlb0018
....There are a wide variety of resistors, and I have not a clue which one works best.
just to be sure , you need "power" resistors, i.e. ones which will cope with at least 10Watts. If you go to somewhere like Maplins, they'll be able to help.
Although they will be seeing more that 10W while the current is flowing, they are only on for half the time (approx) so you can get away with it.
25Watt resistors are only a few pence dearer than 10W versions usually, so would be ideal if you can get them.
Typical general purpose electronic application resistors are often only 0.25Watt, so are definitely NOT suitable.
Old 16-02-05, 06:23 PM   #6
ahlb0018
Default Good to know!
Good to know, that is a huge help! Thanks a lot!
Cheers!
Old 17-02-05, 05:28 AM   #7
ahlb0018
Default problem being fixed.
Firstly, 10W 10ohm are not suitable for this application as I found out this evening. However, after adding a second resistor to the parallel connection (thus creating a 20W 5ohm resistance), the blinker speed dropped to a perfect rhythm. This would be fine, but for the heat generated by using multiple resistors unsuitable for the application (not to mention that they are a bit bulky). So, a set of 25W 5ohm resistors were ordered this evening, which will surely do the trick.
Lockhart phillips stands by their claim that the signals that they make are suitable for 12V applications and installations, but did not divulge the fact that the LED lights that are swapped in place of the existing traditional 21W bulbs (03+ SV650) use far less power and thus blink at a far advanced rate.
25W 5 Ohm
Cheers!
Old 17-02-05, 10:02 AM   #8
H-Gerickemark
hein gericke now doing them for about £11.99, along with a whole new range oF LED indicators
Mark
resistors for indicators sv650nutter149 Stuff Wanted 2 08-02-09 08:39 PM
Resistors or relay Jussi SV Talk, Tuning & Tweaking 4 05-03-07 07:17 PM
resistors for lED indicators Quiff Wichard SV Talk, Tuning & Tweaking 13 27-04-06 07:00 PM
WHO PM'd ME ASKING FOR RESISTORS? Cloggsy Idle Banter 6 11-04-06 10:54 AM
Resistors for LED indicators? moodyman SV Talk, Tuning & Tweaking 8 07-02-05 10:44 PM
