Old 28-02-05, 08:11 PM   #1
SPeeeeDY
Default what parts do i get to keep when restricting a carbed model?
i know this is the most boring subject on here now but can just one person answer and get it out of the way with quickly
Like when a FI model is restricted the CDI (or summat like that) is changed and you should keep the origional one.
When a carbed bike is restricted is there any washers or anything else i need to keep to put the bike back in standard form?
cheers
SPeeeeDY
Old 28-02-05, 08:17 PM   #2
spudnuts
no.
spudnuts
Old 28-02-05, 08:19 PM   #3
SPeeeeDY
ok
cheers
Old 28-02-05, 08:50 PM   #4
454697819
depends on the restriction: If yo get an F1 international kit the No.
if you get a suzuki kit then yes, the old carb sliders and spacers!
If its anew sv then yes, the origonal ECU Box
Should clarify It!
Old 28-02-05, 08:57 PM   #5
SPeeeeDY
cheers
I didnt think CDI sounded right neither.
SPeeeeDY
Old 28-02-05, 09:13 PM   #6
454697819
Originally Posted by SPeeeeDY
cheers
SPeeeeDY
ECU = electronic control unit
ICU = Ignition control unit
CDI= model of car!! lol
Old 28-02-05, 09:52 PM   #7
TSM
The Sick Man
TSM's Avatar
CDI = Capacitive Discharge Ignition
All modern bikes have a CDI to control the sparks on the engine instead of a unreliable magneto unit.
ECU = Electronic Control Unit
Most bikes now have one of these, they are a more advanced version of the CDI. Unlike a CDI where it does the same thing again and again without change, a ECU can learn and do several other things such as control the fuel pump speed, restrict your bikes speed (33bhp), control the PAIR system and also act as a CDI unit. Also modern ECUs that are fitted to Honda's have the HISS system built into them to make overiding and riding them away near impossable.
Anybody correct me if i am wrong
The CDI on a K2 is just behind the rear cylinder, a small round box about 15cm long with power direct from the battery, timing wire and two HT leads to the plugs.
Old 28-02-05, 09:55 PM   #8
SPeeeeDY
all too complicated for me....ill take your word for it
cheers
SPeeeeDY
Carbed model sprocket carrier spacers northwind Stuff Wanted 0 30-03-08 03:23 PM
Carbed model SV-N clocks northwind SV Talk, Tuning & Tweaking 8 26-01-08 01:36 PM
Carbed model clocks wanted, N or S northwind Stuff Wanted 0 16-01-08 05:30 PM
Carbed model fuel tank bits- petcock, sender, cap northwind Stuff Wanted 0 31-05-06 08:05 PM
Silver rear wheel for carbed model northwind Stuff Wanted 4 01-12-05 01:23 AM
