Old 04-03-05, 08:19 AM   #1
keithd
Default fitting R&G's to my "S"
do i need to support my engine when replacing the engine bolt?
i'm pretty ignorant when it comes to things mechanical, the destructions which came with the bars didnt say i needed to to but i swear i saw somebody mention it the other day.
ta very
Old 04-03-05, 08:22 AM   #2
Viney
No. Undo bolt slide out, slide new bar in (Put one nut on the end 1st, then slide through cup) put on other cup, tighten up nut to 65nm, then add black nylon bungs to tatse
Old 04-03-05, 08:31 AM   #3
keithd
you da man viney!! cheers for that. pint on its way
ps 65nm...? is that one or two grunts?
Old 04-03-05, 08:38 AM   #4
Viney
Thats tighten until it shears, then back 1/4 turn
Just do it up FT (Fecking tight)
Old 04-03-05, 08:57 AM   #5
RenamedMonkey
Do you have lowers? You'll have to cut into them if you do, sadly.
Old 04-03-05, 08:57 AM   #6
keithd
aaahh...the old feeling of a bolt just as she shears! not many things more anoying in the world
i'm ALWAYS tempted to think "it'll be ok as long as i dont move it again!"
Old 04-03-05, 08:58 AM   #7
keithd
yeah i do. two or three times i've been ready to cut into it, but just can't bring myself to do so
Old 04-03-05, 09:11 AM   #8
mattSV
mattSV's Avatar
Keith - not sure where in Soton you are, however I have an Abba stand & a torque wrench if that helps.
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 04-03-05, 09:13 AM   #9
Ed
Default Re: fitting R&G's to my "S"
ta very
Yep that was yours truly. The instructions for the Hornet ones say to support the engine with a trolley jack before you remove the bolt. I think R&G are covering themselves in case the engine moves when you take the bolt out. The motor didn't shift at all when John did mine. In any case the pipes go under the engine so there's nowhere to put a trolley jack anyway. A week later the engine still hasn't fallen out so I think it's there for keeps
Old 04-03-05, 09:15 AM   #10
keithd
nice one matty, cheers for the offer, but have access to a paddock stand.
for the record i'm between winchester and southampton
Using "Pointy" Tensioners in a "Curvy"? dtr125 SV Talk, Tuning & Tweaking 25 05-02-09 05:42 PM
Fitting a Leo Vince Carbon to my K7, where is the "how to"? Krokill SV Talk, Tuning & Tweaking 6 21-07-08 07:26 PM
Rideout "Sections" or "Groups" independentphoto Bikes - Talk & Issues 19 04-09-07 01:08 PM
Front "Braker" or "Rear "Braker" &q BURNER Bikes - Talk & Issues 9 27-02-05 01:04 AM
