Old 29-03-05, 07:48 AM   #1
Amanda M
Default Missing a cylinder
I know it's not an SV but I was hoping someone will be able to help me.
The raptor has started running onto one cylinder intermittently. The other day it would do it for a second or so and then be fine and it's got prgressively worse and worse where now it will hardly pull from rest and is rougher than a badger's ar5e everywhere through the rev range and will not run properly at all.
I've changed the plugs, put injector cleaner in the tank and sprayed pug caps and HT leads with WD40 in case it was those and it's worse than ever this morning and died going through a set of lights.
I'm getting to the stage where I'm scared to ride it because I don't know what it's going to do next.
Can anyone help me because I'm really really fed up now and don't know what else to try.
Old 29-03-05, 08:00 AM   #2
Viney
Italian Electrics...need i say more
Id check all the normal stuff like leads to coils, leads to plugs. Look for wires shorting on frame etc.
Old 29-03-05, 08:07 AM   #3
Mike1234
Er, how can the electrics from a TL1000 be Italian?
Old 29-03-05, 08:34 AM   #4
MitchC
It's a Cagiva Raptor not a TL...
Mitch
Old 29-03-05, 08:36 AM   #5
Amanda M
Mitch
You're right Mitch but the engine and most of the electrics are TL 1000 though
Old 29-03-05, 08:43 AM   #6
wyrdness
Have you tried replacing the HT leads? Check the wiring. If not, it could be the fuel injection sensors. My Ducati had similar problems when the FI sensors started playing up. If it's reading the temperature of the cylinder incorrectly then it will be getting the mixture wrong which could cause this sort of problem. As others have said, 'Italian electrics'
Old 29-03-05, 09:55 AM   #7
Viney
Dont play word games with me rodney
Ok then, Jap el;ectrics installed by Italians..
I'll get my coat
Old 29-03-05, 11:10 AM   #8
jonboy
As you've only recently bought it from a dealer Amanda why not take it back and politely but firmly demand they put it right?
Old 29-03-05, 02:03 PM   #9
Scoobs
Agreed!
Amanda, I hate to say this, but it does sound like a bit of a lemon at the moment. I really hope that you get it sorted. Get back to the dealer and get them to put it right. Hopefully, it will just be teething problems and then it will all be perfect.
Old 29-03-05, 02:19 PM   #10
Viney
You should have kept the SV.
Scoobs, Sig...Funky cold Medina - Tone loc??
Missing you already..... Vickster Idle Banter 47 01-10-08 12:22 PM
What I'm missing for the AR... Gordon B 2008 Annual Rideout 19 01-07-08 01:00 PM
That missing something... Alpinestarhero Idle Banter 11 02-12-06 09:05 AM
Missing my SV Ward8124 Idle Banter 3 02-03-06 01:25 PM
missing my SV Wiltshire7 Photos 15 17-08-05 09:49 PM
