Old 19-05-05, 03:15 PM   #1
DanDare
Default Rear Hugger
Hello All,
Fancy fitting a rear hugger to my bike, have had a look around
but actually prefer the genuine one from Suzuki.
Has anyone fitted one of these themselves for a K4? And if so is it pretty easy??
Old 19-05-05, 03:18 PM   #2
richwill68
Default Re
Waiting on delivery of one for my curvy. I'll let you know how it goes.
Old 19-05-05, 03:29 PM   #3
Ceri JC
I have the official K4 one. Look and fit is very good. Fitting is easy, only difficulty I had was of the two points on the swingarm (currently holding your chainguard on), the rear one had seized up. Gave it a good soaking in WD40, tap with a hammer (tap mind- not a clout!) with a cloth on it to prevent denting etc. reapplied WD40. Did this 3 days on the trot, heating it with a hairdryer on one occassion and it finally popper loose.
Thankfully, the replacement ones that come with the hugger appear to be stainless steel
Might be worth checking if any of the bolts have seized and if they have, try loosening them first. Other than that, there's just the obvious, make sure it's not dragging on your tyre.
Would I buy it agian? definately, I've not seen a better aftermarket one and it's not massively more pricey to get an official one.
Old 19-05-05, 03:31 PM   #4
markfc
cool, how much did you pay for your official hugger?
Old 19-05-05, 03:43 PM   #5
Ceri JC
£142 (not fitted). Some of the cheaper aftermarket ones need spraying, which obviously negates a lot of the cost saving (if you have it done well), unless you have access to a spray gun/colour matched paint.
black rear hugger or carbon rear hugger? chipnix SV Talk, Tuning & Tweaking 9 05-07-07 04:05 PM
Rear hugger! dowdy01 Stuff Wanted 0 19-04-07 06:58 AM
Rear Hugger krhall Bikes - Talk & Issues 19 01-03-07 03:55 PM
Rear Hugger krhall Bikes - Talk & Issues 9 28-01-07 11:25 AM
rear hugger for k3 james160987 Stuff Wanted 0 11-01-07 09:58 PM
