Old 06-06-05, 01:13 PM   #1
Bikerz
Default Throttle cable problems?
the carbed SV, turn bars to left and bike revs to about 4 k, but fine on right lock, so oversily a throtlle cable catching on the bars or somthing. yet i cant see where its catching so what shal i do?
Sheldon
Old 06-06-05, 01:41 PM   #2
First make sure it's not adjusted too tight, there needs to be a little slack in the throttle cable for just this reason, adjust the cables so that the twistgrip can be turned about 2-3mm before the engine note changes at all, and ensure that the bars can turned from lock to lock without the tickover being affected.
There are two cables, the opening cable is the front one on the twistgrip housing, this is the one that may be lacking enough slack.
k5 throttle cable help??? ben650 SV Talk, Tuning & Tweaking 2 21-01-08 11:40 PM
*@?><?!!$% throttle cable !! ARRRGHHHH Captain Nemo Bikes - Talk & Issues 1 29-05-07 03:18 PM
Throttle Cable Adjusters svgirl78 SV Talk, Tuning & Tweaking 2 28-08-06 08:45 PM
longer throttle cable? ben650 SV Talk, Tuning & Tweaking 2 01-02-06 07:30 PM
Throttle Cable M65 SV Talk, Tuning & Tweaking 5 23-06-05 08:48 AM
