Old 09-06-05, 12:29 PM   #1
pedrosis
Default scottoiler
does a scottoiler ruin the look of a bike at all??
can someone post some pics please before i spalsh out??
Thansk
Old 09-06-05, 12:30 PM   #2
thor
Err, depends where you mount it!
No, if the resoirvoir is under the seat, you would be hard pressed to tell it's there or not.
Old 09-06-05, 12:45 PM   #3
fizzwheel
fizzwheel's Avatar
Not if you hide it away no, TBH its not that distracting and will save your chain and sprockets so I think its worth it in the long run
Old 09-06-05, 12:51 PM   #4
PoRk ChOp
If you stick it under you seat, then you cant tell it's on the bike. Get one, they are worth their weight in gold
Old 09-06-05, 12:57 PM   #5
BillyC
BillyC's Avatar
I could take a picture of my bike... but you'd be hard pushed to see the tubes and delivery nozzle, so there's really no point.
Yes, my swingarm is dirty, as is my back wheel... but I did have the scotty turned up too high for a while, and haven't got around to cleaning yet. :P
Old 09-06-05, 01:15 PM   #6
Ceri JC
On the subject of the scottoiler, what did people with K4s use to glue the pads that hold the tubing to the swingarm, the standard superglue, or the epoxy (recommended for brushed aluminium swingarms)?
I ask as I'm replacing the tubing and if possible, would like to avoid using cable ties to hold it in place this time.
Old 09-06-05, 01:32 PM   #7
DeeJay
From what i have been told, nothing really works to hld that stuff on... it will peel away...
if i am wrong then please say, cos i would be interested too...
Old 09-06-05, 01:56 PM   #8
BillyC
BillyC's Avatar
You really don't need to glue it to your swingarm!
Mine's zip tied on... but you don't even need to do that, if you route it correctly!
Old 09-06-05, 02:14 PM   #9
Ceri JC
Are you using the dispenser plate (that bit of metal you screw into the swingarm bobbins hole) on the delivery end? That wasn't on mine last time, so I'm hoping I'll be able to get away with just using that and glueing the mounting sleeves (those 2 transparent bits of plastic) in place.
As I suspect the tear in my last tube was caused by it being glued in place, firming up the suspension (so bending it a bit more) and going over bumps at speed, I'm keen to keep a bit of slack in it this time round.
I had a look at Sid Squid's at AR05 and it was very neatly done, so I'm hoping to do something similar.
Old 09-06-05, 02:17 PM   #10
Saint Matt
My dads got one on his, im bored at home so its no trouble to take a pic if you'd like, his is zip-tied on with the reservoir under the seat.
Scottoiler Mk 7 vardypeeps SV Talk, Tuning & Tweaking 4 29-12-08 04:44 PM
Scottoiler ihitge Bikes - Talk & Issues 10 12-08-08 03:37 PM
Scottoiler Dualcyclone SV Talk, Tuning & Tweaking 45 15-03-08 04:46 PM
?? scottoiler ?? DoubleD SV Talk, Tuning & Tweaking 20 16-08-06 04:51 PM
Like a scottoiler for £15 Stu For Sale - SV's and SV related items 0 06-07-06 12:35 PM
