View Poll Results: Which grade of fuel do you use
Unleaded 95RON 18 64.29%
Super unleaded 98RON 4 14.29%
Shell optimax/BP Ultimate 97RON 6 21.43%
Diesel! (Im a muppet i am) 0 0%
Voters: 28. You may not vote on this poll
Old 10-06-05, 08:52 AM   #1
Viney
Default Fuel
So on a regular basis what do you use?
Old 10-06-05, 08:54 AM   #2
creamerybutter
Just your standard Unleaded for me, I'm too cheap for anything else.....
Old 10-06-05, 08:57 AM   #3
weegaz22
i usually use a bit of both, normal unleaded and optimax/ultimate, depends on which petrol station i use, in saying that, i bought a tank of optimax a few weeks ago and it fooked my bike up good and proper...must have been water or a lot of crud in the fuel, soon as the tank was drained and fuel replaced it was fine again, strange as its usually a busy petrol station
Old 10-06-05, 09:02 AM   #4
fizzwheel
fizzwheel's Avatar
Standard stuff for me, I do try and stay away from supermarket fuel though if I can
Old 10-06-05, 09:04 AM   #5
Viney
For me, its Optimax/Ultimate, then Super, then regular.
Never, to date, have i had an issue with supermarket fuel, although i know some people do
Old 10-06-05, 09:07 AM   #6
keithd
i have a diesel car, so i have to vote for diesel. i resent being called a muppet however!
Old 10-06-05, 09:07 AM   #7
fizzwheel
fizzwheel's Avatar
I havent either, The keep having spells of putting diesel in the unleaded tanks at the local Asda though, I think they have done it 3 times now, muppets
Old 10-06-05, 09:08 AM   #8
BillyC
BillyC's Avatar
Viney, I think your poll options are wrong...
It should be:
- Super unleaded is usually 97 RON
- BP Ultimate is 97 RON (so just BP's super unleaded)
- Shell Optimax is 98.5 RON
I always use Optimax in the car.... and when I can be bothered, in the bike. However, it's now more expensive than it used to be
Old 10-06-05, 09:08 AM   #9
weegaz22
ill be using optimax/ultimate more often once i fit my 5 degree advance key
Old 10-06-05, 09:11 AM   #10
weegaz22
billy isnt ultimate supposed to be higher than that??
Fuel @ the NEC Bassman SV Talk, Tuning & Tweaking 4 19-11-07 12:24 PM
Not Fuel, so who else is there? Berlin Exhausts 7 05-09-07 04:11 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
Dry fuel BURNER SV Talk, Tuning & Tweaking 8 18-11-05 05:09 PM
Fuel cap? Bikerz SV Talk, Tuning & Tweaking 3 06-06-05 08:46 PM
