Where is it best to take 2 leads from to wire up a switch if u have no ignition lock to stop *******s pinching it as a quick fix for this week? il oversily have locks around wheels and never let it out of my site but just to be safe any ideas? bar removing igntion fuse
Take rear seat off and unplug ECU. Can't run if it isnt fed. Cant get to it without a key.
Stick a cover on it and nobody'll know?
Under the right hand bodywork at the rear of the curvy 650 bikes, to the right of the riders seat, there is a loopback plug which is connected to the starter system, I'm not sure if it's there on the 400, or why it's there, although I'd guess it's for part of the starter lockout system not fitted to UK bikes. If you were cut the loop, extend the wiring and put a switch under the seat for instance, you'd easily have a cut out switch.
I've used this connection when fitting an alarm to a number of SVs for the starter immobiliser, it's made for the job and doesn't require you to strip the loom apart.
Aint it good when we have an expert on the site
cheers all
the ecu is it this black box with wires going into it? there a clip on top i push down but still get pull the bugger out,is that how i take it out? shall i just pull harder?
Sid Squid - could you take a photo when you have a chance to show us?
Thanks cb9002 |
#9 |
its alright i got it! just needed to pull harder!
Chris pillion seat off far back of pillion space black box, push clip donw be patient and jiggle it a bit and wont be long b4 it comes out! Chris ur in chelt mate next to me, wana meet up some time? if u see silver sv400s with twin high rise carbon cans, whearing richa black and grey leathers and arai lid, thats me. go to collage at gloscat in chelt. |
#10 |
Glad you got it sorted
New plate light has only one wire? | Baz | SV Talk, Tuning & Tweaking | 16 | 29-12-08 02:12 PM |
The Wire | Razor | Idle Banter | 5 | 25-07-08 06:32 PM |
Safety-wire on the SV650... | clm2112 | SV Talk, Tuning & Tweaking | 9 | 28-10-07 03:04 AM |
Unidentified wire | yorkie_chris | SV Talk, Tuning & Tweaking | 6 | 15-09-07 08:46 PM |
wire mesh | bikerskez | SV Talk, Tuning & Tweaking | 3 | 04-02-07 11:45 AM |
