Old 05-07-05, 12:39 AM   #1
Shooter
Default Heated Grips - Oxfords
I searched the forum and found there were two types of Oxford Heated Grips available. It was impossible to distinguish which were which and for which purpose from the dialogue.
It appears one is for alloy bars and the other for steel bars. (Seems a free hat came with one model and not with the other)
Anyone know the model numbers but even better, anyone know which would be best for a Ducati S4 Monster with solid alloy bars ?
Thanx
Old 05-07-05, 02:53 AM   #2
I think every one there is out there now, unless it's old stock, will be the newer version which works with alloy bars. If you search for Oxprod's posts on the subject all should become clear
Old 05-07-05, 03:21 AM   #3
Shooter
Got it - as clear as mud
Quote OXPROD
"Let me explain this better so everyone who visits gets the full story:-
OF695 with a beanie hat is 2004 version (no problem fro the SV)
OF695 without the beanie is 2003 version (not suitable for any bike with aluminium bars, including the SV)
OF695X is the late 2003 version which was updated to be suitable for aluminium bars.
They will not be hot enough for most peoples taste on any bike with aluminium bars. I believe the SV has always had aluminium bars."
Mine are OF695 2004/05 with aOxford multi purpose tube (not a beanie) but anyway my question is I hope they will work with my bars which are solid alloy - NOT tube alloy.
Old 05-07-05, 11:11 AM   #4
Peter Henry
Shooter...Please forgive my ignorance here,( ) but the other day you mentioned to me about fog. What season are you guys in down there at the moment?
Old 05-07-05, 02:44 PM   #5
Should work the same for tube or solid I imagine... All it is is a bit of insulation between grip and bar so the bar material shouldn't make any difference.
Old 05-07-05, 10:01 PM   #6
Shooter
Peter
We are mid Winter here in NZ.
Winter is a relatively mild event in my region eg no snow (ever) and temp ranges 4 overnight to 14 Celsius during the day. Occassional frost. There is probably never a day that one could not ride, unless you hate rain (and we get a bit of that in Auckland).
Fog is just un naturally cold ( I hate it actually and I also detest the drivers that do not use their lights in the fog - another issue)
...any way - hence the Heated Grips.
Biggest problem now - the butt ugly control unit that has to install somewhere handy and visible.
Old 06-07-05, 04:43 PM   #7
I think Oxprod said you could replace it with a switch- though you'd lose the adjustability.
Heated grips Daywalker Bikes - Talk & Issues 3 17-02-09 01:08 PM
Heated Grips? smidge26 Riding Gear 41 09-11-08 01:06 PM
Heated grips skint Bikes - Talk & Issues 19 06-01-07 10:09 PM
getting heated grips off -more help please!! jenni SV Talk, Tuning & Tweaking 21 07-12-06 05:53 PM
Heated grips jimbobule Idle Banter 3 09-01-70 09:04 AM
