I'm new to this biking lark (bought SV650s K3) and in a desperate bid to avoid lining the pockets of my local dealer to much, try to do as much as possible myself. However have run into a slight problem. When travelling along in 3rd, open the throttle, engine revs, not much go. I've adjusted the clutch cables, but still having problems. Had a look in the official service manual and there is a nice picture telling you which screws etc to undo, but for the hapless amateur it doesn't tell you what to do next. Can anyone help to avoid a very slippy clutch and give me more go?
Cheapest solution....
I know it sounds silly but what revs are you changeing up at? Could you just be changeing up too early? Dan |
Look here.
Sid Squid knows what he is talking about, but also I did mine from the manual. Read it first and get it straight in your head, then give it a go. I thought it was reasonably simple following the manual.
#5 | |
![]() Scoobs - Outside. NAH !
#6 | |
Cheers will give it a go.
Thanks, |
Clutch Problem? Cutting off when releasing clutch in first gear! | puthsardarade | SV Talk, Tuning & Tweaking | 15 | 09-01-08 09:42 PM |
hey new clutch advice Kyoto Clutch | srxaus | SV Talk, Tuning & Tweaking | 3 | 14-08-07 04:25 PM |
clutch kit | sv650nutter149 | For Sale - SV's and SV related items | 0 | 25-06-07 03:08 PM |
clutch has had it! | socommk23 | SV Talk, Tuning & Tweaking | 8 | 10-03-06 06:21 PM |
Clear clutch covers to see the clutch spin while running. | TLRMAN | SV Talk, Tuning & Tweaking | 13 | 01-11-04 02:18 PM |
