Old 02-08-05, 10:57 AM   #1
aimhamilton
Default Engine casing!
Hi All,
The K3 SV650S that I recently acquired had been driven fairly hard through the winter months and is showing the signs. The most annoying one is on the area shown below (this is not my bike, but the only picture I could find at work).
The casing looks bubbled in the bottom corners of the circular bits (on both sides) and some of the metal has come away and looks pretty naff to be honest. Is there anything I can do? Or can I just replace the casings and if so, how hard is this to do...would I need to take all the oil out...would it be best to get my local Suzie dealer to do it for me?
Thanks
Andy
Old 02-08-05, 01:17 PM   #2
AlanSv
mate you should see mine.. knackered!
k3, with 22k miles, and the surface is pitted, and bubbled to hell. Its a disgrace but the dealer said it was normal wear and tear, unfortunately I never followed it up when it first started.
Old 02-08-05, 02:12 PM   #3
TC3
Can you not use something like black hammerite to paint it?
Old 02-08-05, 06:15 PM   #4
aimhamilton
I could do but thought it would be easier to buy a new casing??? Surely you must be able to get this from somewhere?
I would rather not go down the fix it myself route as this may lead to it becoming worse!
Old 02-08-05, 09:23 PM   #5
cheepo suzi build quality i aint happy either
Old 02-08-05, 09:34 PM   #6
echo
Hi
If you choose the paint over route, Hammerite will chip and it will look even worse. Don't have an alternative to suggest, sorry.
Old 02-08-05, 09:36 PM   #7
Cloggsy
Originally Posted by echo
Hi
What about having it powdercoated Would that work with the heat etc
Old 02-08-05, 09:36 PM   #8
p/coated would look good.
Old 02-08-05, 10:04 PM   #9
aimhamilton
Powdercoated??? Sorry for being thick..explain?
Old 02-08-05, 10:49 PM   #10
i'll leave this one to someone else? but i think it baked on?
engine casing/cover 99-02 Demonz Stuff Wanted 3 13-04-09 08:28 PM
Engine casing rot yorkie_chris SV Talk, Tuning & Tweaking 2 06-02-08 05:21 PM
Engine Casing Paint therealvw SV Talk, Tuning & Tweaking 3 14-06-07 05:39 AM
Corrosion on Engine Casing I'm_a_Newbie SV Talk, Tuning & Tweaking 2 31-01-07 12:15 PM
Engine casing paint pops2097 SV Talk, Tuning & Tweaking 3 17-11-05 08:40 AM
