Old 16-08-05, 11:55 AM   #1
NAPA121
NAPA121's Avatar
Default Rear Sprocket
I have a Naked sv650 K4. I put the bike on a pit stand the other day and notice there was a very slight wobble in the rear sprocket when the rear wheel was spun. It was only slight but how true should the sprocket spin? Is this normal?
Regards
Neil
Ex Owner of a lovely Naked Blue K4 SV650
Ex Owner of a Buell Lightning Long XB12Ss
Proud Owner of a Yamaha FZ1-N....Man this thing is quick
NAPA121 is offline   Reply With Quote
Old 16-08-05, 11:59 AM   #2
jonboy
It should be perfect, I'd have it looked at.
Old 16-08-05, 12:05 PM   #3
embee
embee's Avatar
Ideally there should be zero runout, but a little is quite normal. I suspect most of it comes from the way the sprocket/cush-drive assembly is built up and mounted.
Mine has a little, but less than the side clearance between chain and sprocket (maybe 0.5mm ???).
The Service Manual gives a runout tolerance for the disc (0.3mm) but not the sprocket that I can see. I'd suggest it should be in a similar ballpark.
Old 16-08-05, 02:48 PM   #4
NAPA121
NAPA121's Avatar
It is only a slight wobble but as the bike is under manufactures warranty do you think I should take it back?
Neil
Old 16-08-05, 02:52 PM   #5
hall13uk
yes take it back fella, as above there should be zero play/ very little in the sprocket. however it may not be covered in the warranty
Old 16-08-05, 03:08 PM   #6
NAPA121
NAPA121's Avatar
Right. I have just spoken to Sturdy's and he said he needs to have a look at it so I'm going to take it down there on Saturday Morning.
Fingers crossed that if anything is wrong it's covered by the warranty.
Neil
Old 16-08-05, 03:17 PM   #7
hall13uk
Neil
well it maybe covered it depends on, if the sprocket is standard & also have you have changed the tyres
if the answer is no to both then its not your fault & its a warranty job.
Old 16-08-05, 03:24 PM   #8
NAPA121
NAPA121's Avatar
Bikes 5 weeks (2000 miles) old with no tyre/sprocket changes so hopefully it should be covered.
When claiming on the warranty, is there any excess to pay? Does the warranty cover parts and labour?
Old 16-08-05, 03:29 PM   #9
hall13uk
warranty covers cost's labour etc no excess fella, but it does not cver all parts
Old 16-08-05, 05:14 PM   #10
M.C.
M.C.'s Avatar
for the first year everything should be covered except things like tyres (because they could only last you 2 mins if you did a massive burnout in the carpark and blew them up thats your fault) but parts that should'nt need replacing for a couple of years or 8-10k miles should be replaced definatly if it's due to assembly or manufacturing fault.
BTW have you had you 4k service done, because if you have'nt they can use this to get out of doing the work for free.
M.C. is offline   Reply With Quote
Rear Sprocket k6 (S) df1uk SV Talk, Tuning & Tweaking 0 28-04-09 11:23 AM
Rear Sprocket plowsie SV Talk, Tuning & Tweaking 3 05-06-07 07:46 PM
REAR SPROCKET? nikki_sv400s SV Ecosse 4 31-08-06 05:11 PM
What have you got on the rear sprocket??? sv650nutter149 SV Talk, Tuning & Tweaking 20 31-08-06 04:27 PM
47T Rear Sprocket bobit69 SV Talk, Tuning & Tweaking 39 26-03-06 10:53 AM
