Old 29-08-05, 10:56 AM   #1
Fuzz
Default Adjusting carb needles
I have a completely stock SV, soon to be getting a Remus GP Revolution slip on (road legal.) I want to start meddling with the carburettors, and so I was wondering if it is worth altering the needle height, and if so, by how much? I will most likely be rejetting at some point in the near future anyway. DynoJet recommend groove 3 on their needle, same for stock?
Old 29-08-05, 01:39 PM   #2
elmerfud
If it's a curvy, I found raising the needle's 1 notch got rid of the slightly wooly throttle at low revs with the race can fitted.
hth
Old 29-08-05, 04:10 PM   #3
wreckah
try http://www.pdq1.co.uk/ for jets.
you can get any size you want. only about 3.5 BP per set.
I think when you're going to get the carbs out, might as well rejet at once
Old 30-08-05, 01:38 PM   #4
johnnyrod
johnnyrod's Avatar
Raising the needle will richen the midrange but won't cure the lean top end. You can't use settings from one needle on another - they have different profiles. Get yourself a decent air filter and have the whole lot set up on a dyno - it's worth the cash and you can listen to it roaring away at the same time. I went to PDQ for my set up as it happens - top fellas.
Old 02-09-05, 07:18 AM   #5
PeterM
Here's some settings that should be useful for you. I've got a Remus Gand Prix can so we should be similar.
Filter - BMC 20510R
Mains - 160fr / 157.5rr (Mikuni)
Needles - 0984h5-60v2_2.9bt (Mikuni). Set on 2nd clip from bottom.
No raising of the tank, no purchasing of a full jet kit ($$$$) no worries.
Obviously you'd likely need some fine tuning but this should get you in the ballpark. On mine it was good for another 8-9hp at the rear.
Old 04-09-05, 10:19 AM   #6
Fuzz
I couldn't find the jets on PDQ, only the full kits. I'm still a little unsure of what size I'm after. The DJ manual says to use part no DJ138 for an aftermarket exhaust, but as the standard size is 137.5, it doesn't quite seem enough. Or are the part numbers nothing to do with the size (which seems odd.)
Old 04-09-05, 10:33 AM   #7
21QUEST
21QUEST's Avatar
Filter - BMC 20510R
Which BMC filter are you using? the regular one not the full race open top.
Also bear in mind that a Mikuni 160 mains is not the same as a Dynojet 160 mains.
Cheer
Ben
Nemo me impune lacessit.
Old 04-09-05, 10:36 AM   #8
21QUEST
21QUEST's Avatar
See my above post for answer to highlighted text.
Just ring PDQ up. They do them cheaper than anywhere apart from ....
Ben
Old 04-09-05, 10:40 AM   #9
21QUEST
21QUEST's Avatar
Default Re: Adjusting carb needles
Sorry , missed part of original post.
If you are just fitting an end can , you shouldn't need to rejet really. Stick the can on and be done. You can put it on a dyno to check but in general , it should be ok with just an end can.
Ben
Old 04-09-05, 10:58 AM   #10
TSM
The Sick Man
TSM's Avatar
Convertion chart for Mikuni vs Dynojet jet sizes
http://www.ds650.net/mikunivsdynojet.htm
Acording to this sheet, 160 Mikuni are nearly the same as 170.07 dynojet
Cramping and pins/ needles Specialone Bikes - Talk & Issues 27 06-05-09 12:17 AM
Pins and Needles! COLZO Idle Banter 13 08-01-09 08:08 AM
Adjustable needles mwr2452 SV Talk, Tuning & Tweaking 9 07-07-07 08:05 PM
Pins & Needles in Hands MR K Bikes - Talk & Issues 68 08-08-06 06:46 PM
Ignition advance key and carb adjusting Fuzz SV Talk, Tuning & Tweaking 3 18-08-05 12:27 PM
