Old 10-11-05, 10:03 AM   #1
Foey
Default Tyre Clearance
Don't know if this has been asked before & if so forgive me for being a div, i have a Suzuki hugger fitted to my SV & was thinking about getting some Z6's fitted but after seeing the different profile of the z6 at the NEC compared to the stock tyre profile i am a bit concerned that it might rub on the hugger which does sit very close to the tyre, has anyone out there had any experience of this.
Ooooooorrrrr should i just say stuff it & get roadattacks.
Old 10-11-05, 10:31 AM   #2
jonboy
The tyre height should be identical (160/60).
Old 12-11-05, 02:08 PM   #3
RandyO
Tire height varries quite a bit between different tires of the same size spec, my guess is as much as 10mm, maybe even a little more
Old 12-11-05, 02:22 PM   #4
jonboy
If that were the case the the speedo would be seriously thrown out of kilter.
Old 12-11-05, 02:24 PM   #5
wheelnut
I have a Suzuki hugger and also on my second set of Z6 Roadtech, there is no problem with the tyres catching but the Z6 certainly is a round tyre unlike many others.
Think about the word, Hugger, it is supposed to be close :P
Old 12-11-05, 09:20 PM   #6
RandyO
Speedo error DOES varry quite a bit depending on what you have for tires, it varries almost 5% over the life of the tire
Old 12-11-05, 11:05 PM   #7
wheelnut
Why would it alter the speedo reading? the speedo on an SV works on the front wheel and it doesnt matter how much you do a burn out or ride hard, the front tyre circumference will not be drastically changed
Peg Scraping! Need more clearance! dmracing SV Talk, Tuning & Tweaking 13 22-08-07 03:15 PM
Ground Clearance davidimurray SV Talk, Tuning & Tweaking 3 15-08-07 09:32 PM
Ground Clearance davidimurray Bikes - Talk & Issues 0 13-08-07 10:55 PM
Baglux Clearance Lissa SV Talk, Tuning & Tweaking 0 07-03-06 08:56 PM
Valve Clearance Craig SV Talk, Tuning & Tweaking 3 14-02-05 07:34 PM
