Old 18-11-05, 10:46 AM   #1
Assen
Default dented tank
So, something solid and heavy's been dropped onto my bike, and the petrol tank is dented. Does anyone know of somewhere in the South East where I can get the dent pushed back out again? The paint isn't damaged so I'm hoping to avoid a complete respray.
Thanks in advance,
Ali
Old 18-11-05, 04:19 PM   #2
independentphoto
Morrisons Supermarket.
Seriously though, a few of the guys on here have (used and) described how to remedy this using FROZEN PEAS & HOT WATER. I'm sure someone will go into detail. It should save you a few quid.
Garry
Old 20-11-05, 11:32 AM   #3
BillyC
BillyC's Avatar
Very sorry to hear this Alison... did it happen while you were at work? Was it in your work car park? How big is the dent?
There are several ways to deal with this, but all require skill, care, and attention:
1) remove the paint in the dent, and weld on a special stalk. The stalk is then used to pull the dent out, before being cut off, and finished to a smooth surface.
2) remove the paint, fill the dent, sand, prime, paint, polish. Probably the easiest solution.
3) fill the tank with air, and the pressure can be used to push the dent out. Not sure how reliable this is, and I've heard mention that you're more likely to split the tank.
Otherwise, you could always keep your eye out for a new tank... but they're like £400+ from the robbers at Suzuki. Or, you could just live with it
Right.... not heard of this myself, and it sounds a bit far fetched. My search didn't return anything remotely useful.
Old 20-11-05, 12:05 PM   #4
21QUEST
21QUEST's Avatar
here the thread about the pea method
http://forums.sv650.org/viewtopic.ph...er=asc&start=0
Ben
Nemo me impune lacessit.
Old 20-11-05, 05:07 PM   #5
BillyC
BillyC's Avatar
No mention of it actually working though
If it were me (and I also have a dented tank), I'd hide it with filler, and paint; or have it pulled out.
As it happens, I lived with it for a year or more, but have a tank that's now ready for painting
Of course, that doesn't help Alison... however, I don't think there's an easy solution to your problem
Old 20-11-05, 05:29 PM   #6
Mike1234
Default Re: dented tank
Thanks in advance,
Ali
Might be easier, and probably cheaper, to buy another tank.
What model bike do you have and what colour is it?
Old 20-11-05, 08:33 PM   #7
Assen
I don't really wanna buy another tank, I think that'll be too expensive. I'll probably just live with it until my knees have rubbed a bit more of the paint away then I can get the dent filled and the tank repainted, like Billy suggested. The bike wasn't at work - it was 'safely' tucked away in the garage! We have a tube light in there that runs off a heavy battery pack - you plug it into the mains overnight to charge, then it last for about a month. My dad tried to take it down to charge it, but it just slipped out of his grasp and smacked down onto the tank. The dent's about an inch accross, and not that deep, so I;ll probably just put up with it. Thanks for the suggestions though! Oh, and Mike - it's a black 650s k4.
dented curvy tank Nicky S For Sale - SV's and SV related items 0 05-04-09 06:28 PM
dented oil filter?? dual-power sv SV Talk, Tuning & Tweaking 13 01-03-09 02:17 AM
Refurbing dented exhaust, and ideas? the white rabbit Bikes - Talk & Issues 5 03-03-08 09:35 PM
Dented Tank lew893 Bikes - Talk & Issues 3 19-01-07 11:23 AM
Dented fuel tank nuntius SV Talk, Tuning & Tweaking 6 16-12-04 10:56 PM
