Old 03-12-05, 02:19 PM   #1
siementool
Default Screwed
Help!
I have bought a tail tidy for my new K5 SV650, but I am having a problem removing the screw that holds the side panel to the subframe, I have tried WD40, rachet screwdrivers, hammer! etc but it will not budge.
I am also having the same problem with the screw on the left side bar-end.
Tips anyone, as I have paid for items that I cannot fit
Old 03-12-05, 03:38 PM   #2
amarko5
find yourself a piece of brass and a hammer then put the brass drift over the offending screw and give a sharp tap with the hammer this can loosen off corrosion on the threads be carefull not to impact too hard as the frame is a cast alloy.
or get a decent impact driver and the relevant sized hex bit for the end .
when finished change the damn bolt if damaged or put copperease on the threads on reinstall
Screwed. Can you help? ooger SV Talk, Tuning & Tweaking 21 04-10-08 11:09 AM
I'm Screwed..... Girth Bikes - Talk & Issues 4 09-09-07 03:34 PM
Just been Screwed By Letting agency 454697819 Idle Banter 8 06-11-06 08:19 AM
I think I've really screwed up the elecrics this time... Italianjob SV Talk, Tuning & Tweaking 5 12-08-05 04:36 PM
Is my suspension screwed or do I need an upgrade? MattTheLoony SV Talk, Tuning & Tweaking 18 08-07-05 12:09 PM
