Old 12-08-05, 03:55 PM   #1
Italianjob
Default I think I've really screwed up the elecrics this time...
To cut the whole story short I've buggered the datatool alarm on my SK4 while trying to extend the indicators. I cut the wires and soldered an extension onto them. As soon as I tried to switch the ignition the alarm went off and will not stop and the bike will not start Any ideas on what to do?
The alarm is a datatool system 3.
Old 12-08-05, 03:58 PM   #2
TSM
The Sick Man
TSM's Avatar
check the alarm fuse, should possably be a sepeate wire next to the bikes fuse box.
Old 12-08-05, 04:03 PM   #3
Italianjob
checked that, I've also disconnected the battery but the alarm just keeps going on.
Old 12-08-05, 04:03 PM   #4
fizzwheel
fizzwheel's Avatar
Sounds to me like your alarm isnt disarming.
Have you got a spare keyfob ? if so try and disarm the alarm with that
If not find the alarm manual and try and resynch your keyfob with the alarm.
Failing that you might have blown a fuse
Cant really offer much help, I've had problems with my data tool before and the re-sych process sorted them out
HTH
Old 12-08-05, 04:08 PM   #5
TSM
The Sick Man
TSM's Avatar
have you tried dissarming with the security code via the ignition?
I do beleave that there is also an internal fuse inside the datatool unit, but you will need security torx bits to get it open.
Old 12-08-05, 04:36 PM   #6
Italianjob
Problem sorted It was the 10A engine fuse.
Did go through a very tense 50 minutes though... Cheers for the advice
Screwed. Can you help? ooger SV Talk, Tuning & Tweaking 21 04-10-08 11:09 AM
I'm Screwed..... Girth Bikes - Talk & Issues 4 09-09-07 03:34 PM
Just been Screwed By Letting agency 454697819 Idle Banter 8 06-11-06 08:19 AM
Screwed siementool SV Talk, Tuning & Tweaking 1 03-12-05 03:38 PM
Is my suspension screwed or do I need an upgrade? MattTheLoony SV Talk, Tuning & Tweaking 18 08-07-05 12:09 PM
