Old 07-12-05, 10:06 AM   #1
Last Action Pimp
Default Oxford Hothands How To!
Here is a How To of How i have fitted my hot hands to my SV, Thor told me about the fuse box connector
Here goes
HOW TO FIT OXFORD HOT HANDS TO A SV650 K3+
DISCLAIMER: As always, it is the owners decision to modify his/her bike. I submit this modification under a blanket policy that states that liability is solely that of the owners and no one elses.
This is only a guide of how i fitted my Oxford Hothands not how Oxford tell you to fit them. i wanted to wire them in so they can only be turned on when the key is switched on the the Ignition. so people cant switch them on and drain your battery when you leave the bike.
Here is the Basic Equipment needed:
You need to remove both seats and lift up the tank,
you now need to cut off the connector on the red wire and strip it
You now need to turn the fuse box upside down to reveal the spare wire slot in the fuse box
get your small flat head screw driver and prise open the connectors in the slot, place the red wire from the hot hands into the slot and use the screw driver to close the connectors onto the wire.
now connect the negative wire to the battery and plug in the switch (i had not hidden the wires yet) now check to see if the green light is on. (the bike must be turned on)
if thats all ok, turn the bike off and tuck the wires into the rear plastics and under the tank after you have attached the switch to the handle bars
(i placed mine in the middle because it is easiest for me)
wrap the hothands around the grips, turn on the bike and run it to see if they work (the green light must be on to tell you they are working)
put the tank down (try not to trap any wires) and bolt the seats back on.
Enjoy!
Old 07-12-05, 10:12 AM   #2
thor
On the pointy there's a spare slot on the underside of the main fuse box. On the K3 it's under the main seat, on the K4 it's under the pillion seat.
Old 07-12-05, 10:21 AM   #3
jim@55
is there a' spare ' take off on a curvey ??im fitting heated grips next week and was thinking of where to take the power feed from as well so as some scrote cant turn them on and walk away and drain the battery
Old 07-12-05, 02:47 PM   #4
Last Action Pimp
its fitted and i have taken photos for a HOW TO,
Old 07-12-05, 03:41 PM   #5
thor
Nice!
Old 07-12-05, 03:45 PM   #6
Last Action Pimp
i will e-mail it to john and get him to put it into the howto
Old 07-12-05, 06:57 PM   #7
I took a tap from the "hot" for the plate light, and used that to run a relay... Wired the grip[s direct to the battery, through the relay, so they're only on when the lights are on.
Old 07-12-05, 11:13 PM   #8
didge
dos it matter if you connect it strait to the battery cos thats what i hav e done
Old 07-12-05, 11:27 PM   #9
jocky
Default hot hands
Cheers. Top pics.
JON
Old 08-12-05, 10:39 AM   #10
Last Action Pimp
yes because it can be switched on when the bike is not turned on, because it takes it straight from the battery wherte as my way it takes it from the fuse box that only gets power when the bike is switched on.
Oxford Aquatex vs Oxford Stormex Thingus Bikes - Talk & Issues 18 11-01-09 04:33 PM
Oxford products gettin2dizzy Bikes - Talk & Issues 47 15-01-07 05:45 PM
Oxford 1st Panniers MavUK Bikes - Talk & Issues 7 30-10-06 09:51 PM
Oxford HotHands TSM SV Talk, Tuning & Tweaking 3 21-02-05 07:54 AM
Oxford 1st time vs Oxford humpback panniers Philbo Bikes - Talk & Issues 15 13-01-05 08:18 PM
