Old 16-02-06, 11:30 PM   #1
_Stretchie_
Large Member
_Stretchie_'s Avatar
Default This little piggy went to market.....
This lttle piggy went home...
This little wire makes the new mini indicators flash...
And this one blows the chuffin lot up....
HELP
New mini's on the rear, with the OE indi's one side had a brown and a black wire and the other side had a green and a black wire. Both the BLACK wires went to the same connection. Hmmm, with my new ones does that mean I put both the black wires into the same connector and the ones with the stripes to be connected to the brown and the green respectivley or vice versa.
Also is the green one the left indi or the right indi???
And last but not least we are talking about a Yamaha Thundercat
Stretchie
P.S. A speedy reply would be awesome because then I can HOPEFULLY finish this bloody tray, get in back on and have a pic on here tonight (providing I don't have to fight with the fairing and I can remeber which screws go where)
How to amuze an idiot:
Look right-> <-Look Left
Old 16-02-06, 11:50 PM   #2
amarko5
if the two blacks are commoned then it is most likely thats your earth or negative
you will need a miltimeter or continuity tester to check your minis take a bulb out of one (or both) then test which wire is the centre conection
this wire will go to the brown or green wire (easy to check which is which ) connect and see when switch is thrown then mount indie on side required
Old 17-02-06, 01:44 AM   #3
_Stretchie_
Large Member
Got it all done and put back together now
Old 17-02-06, 01:49 AM   #4
amarko5
cool
wheres the pics :P
Old 17-02-06, 12:29 PM   #5
I just wired mine up in all available combinations till they worked Works in all manner of applications... Never yet blown myself up, though I suppose it's only a matter of time.
They've turned a beautiful Daytona into a piggy bike! monkey Idle Banter 1 24-01-08 05:54 AM
Where I can get a sucker feet piggy off the shelf? monkey Soho Massive 3 21-12-07 10:58 AM
Piggy Piggy Piggy Viper Soho Massive 41 16-11-07 12:03 PM
This little piggy won gold..... CoolGirl Idle Banter 1 17-04-06 06:28 PM
After Market Can! Need Help? randyryan69er SV Talk, Tuning & Tweaking 14 19-11-05 06:34 PM
