Old 17-03-06, 04:14 PM   #1
will
Default rounded off sump plug - removal, how?
not on the SV, but on my car....
it's not completely shagged, but getting that way.
i am tempted to have a go at it with a stilson wrench. for more experienced mechanics amongst us (SID SQUID....ARE YOU OUT THERE) is this an ok idea, or am i being thick?
also, if the engine is warm, would that make the removal of sump plug easier or more difficult. i'm scratching my head over badics physics - does a warm engine increase the size of the plug therefore making it tighter, or increase the sump size therefore making it less tight........ my head hurts.
Old 17-03-06, 04:20 PM   #2
Anonymous
Default Re: rounded off sump plug - removal, how?
Its a funny one. You'd expect it to get tighter. but in fact it makes it easier to remove.
I had to get a bolt out once and couldnt do it. My mate whos an ex rally engineer came around with a spot welder or something. Put it to it for a split second and pop - out it came. The thread expands, thus making it easier for the bolt/nut to be removed.
Magic huh!?
Old 17-03-06, 04:51 PM   #3
Dicky Ticker
Weld a nut on to it and take it off with a spanner if the grips don't work
Old 17-03-06, 04:53 PM   #4
Viney
Vice grips, or center punch.
Old 17-03-06, 05:03 PM   #5
it isnt a mondeo is it? sump plugs are made of chocolate, the ford dealer told me they always replace the sump plug with a new one every oil change.
Old 17-03-06, 05:05 PM   #6
amarko5
stilsons if you have the room to get at it
Old 17-03-06, 05:11 PM   #7
will
tis a volvo (yeah, i know...sorry)
is there any advantage to the engine being warm before i work on it - GYKD suggests it is, but anyone else?
Old 17-03-06, 05:19 PM   #8
Anonymous
It may work, but im not sure if the engine on its own could generate sufficient heat to create the desired effect. The guy who realised my bolt used a spot welder (i think it was) - it created shed loads of heat in like a second. Worth a try though. If it doesnt work.. you've not lost anything.
Old 17-03-06, 05:20 PM   #9
Viney
I have a volvo, but i had it serviced, so dont even know what the sump plug is like. A warm engine will help a lot to be honest yes.
Sump Plug Torque? skov SV Talk, Tuning & Tweaking 2 27-02-08 08:38 PM
Sump plug washer yorkie_chris SV Talk, Tuning & Tweaking 3 29-09-07 10:44 AM
Oil Drain Plug seized and rounded aliman2000 SV Talk, Tuning & Tweaking 21 10-09-07 04:15 PM
Drilling Out Sump Plug? UlsterSV SV Talk, Tuning & Tweaking 13 15-04-06 05:22 PM
Pants! Sump plug... localhost Bikes - Talk & Issues 12 20-01-06 11:27 AM
