Old 18-03-06, 04:00 PM   #1
JakeRS
Default URGENT - braided hoses - no resistance
Hi guys, bit urgent this one as currently I have no brakes on the front.
Fitted braided hoses, been bleeding the brakes for ages now, all the air has come out of the lines, and there is resistance when the nipples are untightened.
And yet when the bleed nipples are tightened back up there is no resistance on the lever.
Also the right hand side line is pumping fluid through but the left is not.
HELP!!!
Old 18-03-06, 04:06 PM   #2
TSM
The Sick Man
TSM's Avatar
Mabey one of the bolts holding the lines on are not tight enough. Did you use the copper washers?
If the right has fluid pumping through then continue on the left it should eventualy come through.
Old 18-03-06, 04:08 PM   #3
Viney
You still have air in the line Jake. Its a long task of getting air out of the front lines. Go get youreslef a long length of windscreen washer hose and suck the fluid through (DOnt let it get to your mouth). Remember, only do one caliper at a time.
HTH
Old 18-03-06, 04:14 PM   #4
JakeRS
right, both the lines now have fluid coming thru but a lesser amount in one of them.
have the lever currently tied back in to the handlebar in hope...
Old 18-03-06, 04:33 PM   #5
21QUEST
21QUEST's Avatar
More often than not it's air in the master cylinder. You need to bleed it.
Have a look here
http://forums.sv650.org/viewtopic.ph...hlight=#494159
Ben
Nemo me impune lacessit.
Old 18-03-06, 04:59 PM   #6
JakeRS
top stuff! we have the startings of resistance, enough now to stop me, so the lever is tied to the handlebar gonna leave it over night.
thanks dude
Old 04-05-06, 07:35 AM   #7
454697819
Did bleeding the mastercycline do the job?
i was doing my new hoses last night, and although there was air and fluid coming out, i still had no resistance??
help...
Braided hoses on E-bay. Al_Sweetman Bikes - Talk & Issues 22 08-03-09 12:39 PM
braided hoses hovis SV Talk, Tuning & Tweaking 11 18-11-06 11:04 PM
braided hoses hovis SV Talk, Tuning & Tweaking 9 15-11-06 07:03 PM
HEL Braided hoses tricky SV Talk, Tuning & Tweaking 14 20-02-06 10:06 AM
Braided Hoses for a K4 wezza Ancillaries 3 09-11-05 09:54 AM
