Old 12-04-06, 08:56 AM   #1
TSM
The Sick Man
TSM's Avatar
Default Bitz & Peices
All bits are for pre K2 bikes, bits are from a 02' bike though apart from the pointy brake lines.
Jackup dog bones (20mm seat lift & 40mm rear lift approx). - £12 posted.
Carbs (fuel mix screws have been damaged, but are set for normal jetting) - £20
Pointy Stock Brake Front Lines - £10
Curvey Stock Brake Front & Rear Lines - £10
Fuel tank (without fuel cap/valve/sensor) crash damaged on left side, all intact & still holds fuel and with baglux cover is not noticable, usefull for racers. - £20
Kwak ZX6 A1P shock - £25
Rear subframe, only good for project or racing. The regulator mount has been removed & rear lock mount has been damaged.
Clock surround, i have one painted in Y9F, all intact but it was left outside for a long time so is a bit mucky and weathered & possably need repainting
I have some other plastics that i may want to get rid of.
Front Forks (Right ok, Left stanchon has a small crease but was straightened as much as possable, has 10w fork oil and prog springs with preload caps installed & stock springs (boxed), fork lowers are in good condition) - £80 [GONE - Pending Payment]
Front Yokes (Top & Bottom) - £25
Clipons - £20 (Pair)
OEM Full Exhaust System (20k) - £10
OEM Undertray - £10
GSXR SRAD 600 Ignition + Fuel Cap with 1 key (should work on SV) - £20
GSXR SRAD 600 Uprated fork springs - £25
GSXR K2+ Calipers & OEM Lines - £40
Oh and also loads of bits from an RF400
Old 24-08-06, 08:55 AM   #2
21QUEST
21QUEST's Avatar
Default Re: Bitz & Peices
Originally Posted by TSM
...........GSXR SRAD 600 Uprated fork springs - £25
What's the spring rate for these uprated springs?
Check on the end of the springs . Afternarket springs usually have the rates engraved on the flats.
Ben
Nemo me impune lacessit.
Old 24-08-06, 06:33 PM   #3
TSM
The Sick Man
TSM's Avatar
Ben
They have nothing on them at all. I know they are diffrent though as compared to another set of same forks. This spring is longer than the other forks which were sold as completley standard while these were from forks that were setup for the track. Sorry not much help.
Old 04-09-06, 12:56 AM   #4
Phantomtek
Hi will the undertray fit an SK1 model?
Old 04-09-06, 07:54 AM   #5
TSM
The Sick Man
TSM's Avatar
I see no reason why it will not as mine is an SK2
Old 04-09-06, 11:07 AM   #6
Phantomtek
I forgot to ask, what colour is it?
And how much will postage be?
Cheers.
Old 04-09-06, 11:18 AM   #7
TSM
The Sick Man
TSM's Avatar
Cheers.
All OEM undertrays are black, this is the stock one not an aftermarket thing.
Old 05-09-06, 07:13 PM   #8
Phantomtek
Cool I'll take it, how much is postage to Leeds?
Cheers.
Old 06-09-06, 07:33 PM   #9
dougieo
Default FRONT FAIRING
Hi do you have the left front fairing there intact mate cheers
Cheap bits in Byke Bitz Mark_h Thames Valley 2 01-02-09 04:59 PM
Bike Tek Paddock Stand from Biker-Bitz tricky Ancillaries 5 03-12-05 02:06 PM
