For Sale - SV's and SV related items For SV's and SV spare parts only. 650 or 1000 No other items Unsanctioned trade ads will be deleted as will spam and chat. |
HyperPro rear spring to fit Curvy rear shock. 195mm length, min ID 48.5mm, max ID 52mm.
I believe it's a non-linear spring as the coil spacing is not constant, & it gives a more compliant ride than the Suzuki standard O/E rear. I bought it from a forum member a year or so ago, got it blasted & powdercoated in bright yellow....... & then went for a GSXR shock instead. ![]() The HyperPro doesn't fit the GSXR. ![]() Don't know if it'll fit a Pointy's shock. £12 plus £4 or so for carriage. |
The Sick Man
Was the coil the correct spring rate for curvey SVs?
Do you know if it will fit a Penske shock?
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#3 | |
No idea. You'll have to measure the shock body diameter with a vernier or similar, check the length of spring it requires.....basically compare it with a standard SV shock/spring |
The Sick Man
Darn, nop wont fit. Spring needs to be 2.25in. Thanks anyway.
Got a selection of Hypercoil springs which are the right size for a Penske shock. I think lowest is 550 pounds/inch and highest is 700 pounds/inch
Cheers Ben |
Bump
Bump
rear pad locating spring | mudgutsdunn | SV Talk, Tuning & Tweaking | 5 | 14-02-09 02:10 PM |
Hyperpro rear shock spring | DEJA_Vu | SV Talk, Tuning & Tweaking | 6 | 13-12-08 05:00 PM |
Hyperpro Spring Kit | Cam_73 | SV Talk, Tuning & Tweaking | 9 | 19-11-07 08:55 AM |
Another question about rear spring preload. | oldjack | SV Talk, Tuning & Tweaking | 2 | 25-07-06 08:09 AM |
SOLD - Goodridge Rear Brake Line (Pointy Model) - SOLD | Bez | For Sale - SV's and SV related items | 7 | 27-02-06 08:05 PM |
