Old 22-04-06, 07:41 PM   #1
Default Tiscali broadband
a question to anyone who has tiscali broadband, do you keep loosing your connection? some days my connection will be fine and then others it'll drop the line for now real reason this is a pi$$a when your downloading large files.
at the bottom of the screen by the clock you have a green triangle when the b band strenth is good, when the connection is dropped the triangle goes red then yellow then green so i can re connect again, is this a lack of bandwidth?
Old 22-04-06, 09:13 PM   #2
ok any broadband that uses a normal bt line ASDL i think not cable.
Old 22-04-06, 09:40 PM   #3
haggis
What little triangle?
I'm on tiscali too, best connection I've ever had. Maybe half a dozen dis-connects since moving up to BB last October.
If you float the cursor over the connection status icon (looks like two monitors, one flashes) it states your best line speed. (Mine being 2.2Mbps) In reality you're usually a bit below this most of the time. eg. 1.8Mbps is doing well for me.
You can then check your bandwidth here. Do the test a few times over a couple of minutes to get an average.
http://speedcheck.ispconnect.co.uk
Old 22-04-06, 09:47 PM   #4
u using the thomson modem haggis? i'm on the sagem one i just get the green triangle, i think i know what your on about and its with the thomson modem my daughter has that one on her pc.
Old 22-04-06, 09:48 PM   #5
1945.3 kbps on a 2.3mbps connection.
Old 25-04-06, 08:46 PM   #6
haggis
Yeah, Thompson Speedtouch 330.
If yours is theoretically 2.3 and you're getting 1.9 regularly I'd say that's pretty good. Are you quite a way from the exchange? This makes a big difference to as I believe you're first to get disconnected in such cases. I could be wrong. Any comms engineers on here?
Round here, at night the local kids go online gaming and you can feel the refresh times getting dragged down and down with each XBox 360 switching on, little B***ards!
Old 25-04-06, 09:22 PM   #7
yea thats prob what it is, fri sat nites are the worst.
sky broadband Warren Idle Banter 7 31-08-07 05:34 AM
TISCALI trouble? kwak zzr Idle Banter 4 16-03-07 09:10 PM
tiscali broadband? kwak zzr Idle Banter 7 25-09-06 05:14 PM
Which Broadband? M65 Idle Banter 45 19-08-06 11:19 AM
GRRRRRRR !!!!! - tiscali e-mail PLEASE HELP ME !! Captain Nemo Idle Banter 12 27-04-06 04:55 PM
