Old 11-05-06, 02:47 PM   #1
dytron
Default Very hard to find neutral
Can anyone help.
I'm finding it increasingly hard to find neutral when stationery. Its breaking my left foot off!! i took it into the garage and they said they'd adjust the clutch. It was good for about a week now its back to how it was.
Is it the clutch? or something else.
If anyone else has had this problem please let me know.
Toby
Old 11-05-06, 02:50 PM   #2
kciN
Default Re: Very hard to find neutral
Originally Posted by dytron
Can anyone help.
Toby
I had this problem. Apart from saying it being something major, which I'm not, I was advised here that it could be
Too much oil - check the level
Poorly adjusted chain - check the slack..
Some other brainy person will be along soon
Old 11-05-06, 02:50 PM   #3
Grinch
Oil change might help...
Lube the clutch cable...
Or there is a thing at the bottem of the clutch cable that changes your clutch pull in to a push, its a good idea to give it a new bit of grease. Also check none of the bearings in it have perished, if they have grease it up and order a new one.
Can't remember what its called though.
Old 11-05-06, 02:51 PM   #4
dytron
Thanks for that. The chain was adjusted at the garage at the same time. knowing my luck its probably something major!!1
hahahah
Old 11-05-06, 02:54 PM   #5
dytron
Forgive my ignorance, you mean the main engine oil or something different. Yes i've just ordered my Haynes Manual for all basic repairs.
Appreciate your patience!
Old 11-05-06, 02:55 PM   #6
PoRk ChOp
Can anyone help.
Toby
Check the adjuster on the clutch lever, mine works loose after a few weeks and I have to re adjust it and tighten the locking nut again and again
Old 11-05-06, 02:56 PM   #7
Scoobs
The main engine oil is what the clutch sits it. So yes....the main engine oil.
Old 11-05-06, 03:00 PM   #8
kciN
dytron
Read this thread. It's what I posted a month back on a similar subject, except mine was not getting 1st..
Should help...
http://forums.sv650.org/viewtopic.ph...hlight=#520094
Old 11-05-06, 03:03 PM   #9
Grinch
This might help:
Old 11-05-06, 03:40 PM   #10
dytron
ha!
Just checked my oil level and low and behold there seems to be a little too much in there. Bloody garage!
cheers for the info guys
Really hard to find the right leathers help needed please Mgaffz Suits 8 25-04-09 06:55 PM
Hard to find neutral newts924 SV Talk, Tuning & Tweaking 33 02-09-08 09:54 PM
Online CD shop for hard to find CD? Tim in Belgium Idle Banter 9 03-10-07 08:39 PM
Can't find Neutral Stu Soho Massive 7 12-10-06 09:05 AM
bike choking when revved hard and fast in neutral.... branny SV Talk, Tuning & Tweaking 11 05-09-05 08:14 AM
