Old 23-05-06, 08:40 PM   #1
kidpuffy
Default how to change the grips?
how do i remove the grips on the handle bar?
Old 23-05-06, 08:41 PM   #2
Razor
Stanley knife.
Old 23-05-06, 08:45 PM   #3
Grinch
Originally Posted by Razor
Stanley knife.
Or if you want to keep them then just a bit of leaver action with a flat headed screwdriver will do.
Old 23-05-06, 08:48 PM   #4
I use a thin screwdriver, work it down the length of the grip and then all around the 'bar. once it's loosened it'll come off easily.
Old 23-05-06, 08:49 PM   #5
BILLY
Pour boiling water on them to soften the hot melt glue and they just roll off then
Old 23-05-06, 08:50 PM   #6
Grinch
Old grips removed.
Heated grips fitted, lovely and warm, though the right hand does get a bit hotter.
All rather easy and I'm a muppet when it comes to these things.
Don't forget to take the bar end weights off first, if they haven't been moved in a while you might need a impact driver...
Old 23-05-06, 08:50 PM   #7
buttmunch
Screwdriver works, but if they are old and hard, boil a kettle, pour and peel! If that doesnt work, resort to our mate stanley!
Old 23-05-06, 08:56 PM   #8
Diveboy
When fitting the new ones lube the inside with washing up liquid. it dries quickly but make the job 200000% easier.
Trust in my blisters!!!
Old 23-05-06, 10:12 PM   #9
Originally Posted by Grinch
Old grips removed.
perhaps the skin is a bit thinner on yer right hand grinch - (for some reason >??)
PS: I like the watch !
Old 23-05-06, 10:25 PM   #10
Diveboy
Funnily enough I found the same thing it is down to how hard you grip them. Possibly good at making you a more balanced rider
or just showing up how much you grip the throttle
Gel Grips SAMMY650 SV Talk, Tuning & Tweaking 3 10-07-08 09:36 AM
Hot Grips andyb Bikes - Talk & Issues 21 20-09-07 02:23 PM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
Grips? MitchC SV Talk, Tuning & Tweaking 5 01-02-05 03:14 PM
Oil Filter Change with every oil change? Ceri JC SV Talk, Tuning & Tweaking 2 22-11-04 06:02 PM
