Old 12-06-06, 08:26 PM   #1
muzikill
muzikill's Avatar
Default Wheel axle grease type?
Im refitting the wheels after fitting some nice roadtec z6's on and we are talking axles from factory fitted tyres
Any recommendations on what is the best grease to use and some basic info on how i should cover it and how sparingly? and the spacers - i take it i should clean them up a bit first .....
btw thanks so far on all the advice this forum really is the best
Old 12-06-06, 08:38 PM   #2
jonboy
Castrol LM or any decent lithium based grease is the ticket.
Old 12-06-06, 08:51 PM   #3
Richie
fantabulas
Richie's Avatar
XG279 Army code for hub and bearing grease... 5 - 25 litre tub, loads of the stuff.
My Flickr photos
Old 12-06-06, 09:04 PM   #4
UlsterSV
Use Castrol LM meself.
Old 12-06-06, 09:16 PM   #5
yea but thats to slick yer hair back !!
Old 12-06-06, 09:38 PM   #6
andyaikido
I had tyres fitted at Demon Tweeks recently and the grease they used was red. What is it? I'm assuming (hoping) its not rubber grease.
Old 12-06-06, 10:07 PM   #7
jonboy
There's no question that greasing your tyres will significantly increase the mileage you'll get from them .
Old 12-06-06, 10:15 PM   #8
sv650gerbrit
Default Red Grease
Hi-normally red grease is the fully synthetic stuff-will be fine.Good shop if thatys what they used.
Old 13-06-06, 12:05 AM   #9
Richie
fantabulas
Richie's Avatar
look at the burnout...
My Flickr photos
Old 13-06-06, 12:56 PM   #10
andyaikido
Default Re: Red Grease
Well impressed with the service from them. They even cabled tied my scottoiler into a better position on the sprocket. Shame they're in Wrexham and i'm in Manchester, i only used them this time cos the local places were booked up.
Rear wheel axle nut sweepdoggydog Stuff Wanted 0 25-04-09 07:47 PM
GSXR 750 k4 front wheel axle part. Caddy2000 Idle Banter 4 22-12-08 10:56 AM
What is the blue grease used in my rear axle/spacers on my Daytona? monkey Bikes - Talk & Issues 8 01-03-08 07:55 PM
Front axle grease rob13 SV Talk, Tuning & Tweaking 1 03-09-07 06:43 AM
Wheel bearing grease and filter oil big twin grin SV Talk, Tuning & Tweaking 2 05-03-06 10:16 PM
