Old 19-06-06, 12:51 PM   #1
wtdafk
Default how do i burn dvds so they work ??!!!
well thats the question, im used many differnt programmes to try to do it including cheetah and some others but every time i do it they wont work on my dvd player only on my computer. im thinking it must be something to do with the coding but i thaught the burning software would sort that. any idears? the files im trying to do are mpegs mostley
cheers
Old 19-06-06, 01:00 PM   #2
mysteryjimbo
My current drive was a complete nightmare to get set up. In the end, turns out it came with a very old firmware that would one work with certain disks.
Try your manufacturers website for that.
What software are you using and how you using it?
Old 19-06-06, 01:03 PM   #3
wtdafk
im using cheetah and all im doing is selecting the file i want to burn to make a video dvd and then clicking burn, works fine on my computer but refuses to do anything on my dvd player
Old 19-06-06, 01:06 PM   #4
mysteryjimbo
Are you sure your DVD player will play DVD+R or DVD-R (or RW)?
Also, its quite common, more so with cheaper makes, for certain disks not to work.
Old 19-06-06, 01:40 PM   #5
Mr Toad
try using Nero
have you examined the file structure on the DVD that you have written
you should have a folder called VIDEO_TS, and a selection of files in it that end in extensions such as .vob
if not, you've probably just written a .mpg file onto the DVD which a standard DVD won't touch
Old 19-06-06, 01:44 PM   #6
mysteryjimbo
I think the word "most" should be inserted there. There are players that play mpgs. Even DivX too.
Old 19-06-06, 02:09 PM   #7
i solved my burning problem by replacing my writer, my old one just wasnt burning correctly and i was getting that many coasters i didnt know if it was the disks the programmes or the burner its self no probs now tho and it only cost £30 from svp communications (pioneer 111).
Old 19-06-06, 02:59 PM   #8
Mr Toad
Quite true. I replaced my DVD player a few months ago when I came back from holiday to discover it couldn't play/display .jpg files. Got a multi-region Sony something or other that plays absolutely everything - .jpgs run as a slideshow, and if you put a .mp3 track in the same folder it plays that as background music, and all for less than £100
Old 19-06-06, 03:12 PM   #9
wtdafk
hmmm strange ive tryed it on three dvd players with no joy, and have done as said with the TS folder its a brand new computer so should be working fine never had a problem burning music, i shall look in to it further and try not to use up all my dvds in the process ta
Old 19-06-06, 03:18 PM   #10
Gnan
For Sale My DVDS: Kinvig Idle Banter 7 24-02-08 12:12 PM
DVDs for sale Jackhammer Soho Massive 3 16-10-07 08:15 AM
Win new DVDs ! pete m Idle Banter 2 15-12-06 06:53 PM
GP videocassettes / DVDs Damoulianos Marios Bikes - Talk & Issues 2 13-06-06 01:00 AM
DVDs for sale pete m Soho Massive 2 17-01-05 09:38 PM
