Old 06-07-06, 01:22 PM   #1
creamerybutter
Default fitting new discs and pads on the front.
I have my lovely new discs and pads and I think I know what to do, Remove the wheel, remove the discs, put on new discs and put new pads in calipers and then replace wheel. Is there anything else I sould consider/do for example will the brakes need bleeding etc? Also the manuals don't mention putting any greese on the axle, is this right?
Old 06-07-06, 01:33 PM   #2
Khewett
Default Re: fitting new discs and pads on the front.
Its as easy as that!
May need to push pistons in a maybe empty a little fluid from the resivour.
Dont need to bleed your brakes again.
I do greese the axle a little when I take it out.
Old 06-07-06, 02:03 PM   #3
creamerybutter
Cheers, also how long does it take to bed in new pads/discs. I'm trying to decide if I will put them on tonight or after I get back from the rideout.
Old 06-07-06, 03:05 PM   #4
lukemillar
I have seen people use non-permanent thread-lock on the disc bolts. Not sure if this is essential or not, though I'm sure someone will be along to comment.
Old 06-07-06, 03:18 PM   #5
Patch
Clean the discs with a solvent based brake cleaner before you fit them so that manufacturing and storage lubricants do not contaminate the brake pads.
Old 06-07-06, 03:25 PM   #6
creamerybutter
Aye forgot to mention the threadlock, although the bolts I have got (as my old ones are all shabby lookin) are blue on the end, do these already have thread lock on them?
Patch: will do cheers.
Old 06-07-06, 03:33 PM   #7
Flamin_Squirrel
Yes, the new bolts come with thread lock already on them.
Old 06-07-06, 03:45 PM   #8
chazzyb
How do they do that? The only thread lock I've ever used is liquid and goes off when exposed to air.
Old 06-07-06, 04:02 PM   #9
Biker Biggles
Biker Biggles's Avatar
Front wheel fitting---Be extra careful not to break the speedo drive rota.It's made of self destructing material.
Old 06-07-06, 05:13 PM   #10
lukemillar
Just what I was thinking?
which discs and pads? svtomo SV Talk, Tuning & Tweaking 4 06-07-08 09:37 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
Brake Discs for GSXR front end conversion on SV 320mm discs Ter For Sale - SV's and SV related items 0 22-09-06 04:50 PM
pads and discs scraping rob13 SV Talk, Tuning & Tweaking 9 09-02-06 06:42 PM
New discs...................old pads??? svrash SV Talk, Tuning & Tweaking 9 30-11-05 08:50 PM
